Does your steering wheel "clunk" when off road? The zip tie fix will make your day!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedRocket07, Jun 1, 2016.
Did the zip tie mod work for clunky Tacoma?
  1. Yes
    69.0%
  2. No
    31.0%
  1. Aug 22, 2017 at 8:42 PM
    #61
    Dwrat
    Dwrat Well-Known Member
    Dan
    Phoenix
    2014 TRD 4X4
    Thanks for this tip, I just did the zip tie fix.
    Hopefully no more clink.
  2. Aug 22, 2017 at 8:43 PM
    #62
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    Yee! Worked like a charm
    Keith Nguyen and TXpro4X4 like this.
  3. Sep 6, 2017 at 1:22 PM
    #63
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    I used 2 small zip ties and it seemed to do the job. Can't quite tell yet.
    TXpro4X4 likes this.
  4. Sep 6, 2017 at 9:52 PM
    #64
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Take it on washboard dirt road if you have any
  5. Oct 3, 2018 at 5:33 PM
    #65
    Mr. Farknocker
    Mr. Farknocker New Member
    I had a hard time seeing the zip tie so I edited the photo to help all of the blind guys (like me).
  6. Oct 3, 2018 at 9:15 PM
    #66
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Mine clunks. I need to do this, just haven't gotten around to it yet.
  7. Oct 4, 2018 at 4:27 AM
    #67
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I needed to zip tie mine in a way to put upward pressure on my rag joint. Simply wedging a zip tie in there didn't do it for mine. 90% quiet now
  8. Oct 4, 2018 at 10:36 AM
    #68
    ImpulsedComa
    ImpulsedComa Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    pics?
  9. Oct 4, 2018 at 4:33 PM
    #69
    Northern Taco
    No pics, but just grab the joint and push/pull up and down, you'll hear a clunking. Zip tie it in a way that limits this up and down slack
    ImpulsedComa[QUOTED] likes this.
  10. Oct 4, 2018 at 8:33 PM
    #70
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Could the clunk be confused to seem like its coming from below floorboard?
  11. Oct 5, 2018 at 3:21 AM
    #71
    Northern Taco
    What I had, you could feel it in the wheel and replicate it by grabbing the rag joint/column and shaking it
    Slvr14tacoma[QUOTED] likes this.
  12. Nov 30, 2018 at 2:54 PM
    #72
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Thread revival.
    I have the clunk, but the tolerances are still tight enough that I can't fit even a tiny baby zap in the gap. I wonder if I should try something firmer ... any ideas?
  13. Dec 11, 2018 at 12:06 PM
    #73
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    A metal shim maybe.
    Did you try turning the wheel and see if you cant get it to open up a little?
  14. May 22, 2019 at 8:19 AM
    #74
    Beagle1
    Beagle1 New Member
    2012 DC 4WD
    Did this 3 weeks ago. Works well. The mechanic was suggesting getting a new steering coupler which would have been a lot more expensive and wouldn't solve the problem in my opinion. Initially I had an issue visualizing what should be done with the zip tie until I realized that it wasn't to be use to tie anything in place but to be placed between the small space to prevent the rattling.
    Weissenheimer and TXpro4X4 like this.
  15. May 22, 2019 at 9:26 AM
    #75
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Sweet!
  16. Jun 9, 2019 at 6:34 PM
    #76
    Nod69er
    Nod69er New Member
    Don-don
    West Covina, CA
    2007 Blue Toyota Tacoma SR5 PreRunner Double Cab Long Bed
    None
    Hey fellas I have this issue now after replacing the driver side LCA bushings and ball joint. Most of the front bushings were replaced subsequently and torqued. Sadly even after greasing and soaking the intermediate shaft u joint with PB blaster, the clunking, although it momentarily went away, for a few minutes, is back--and worse. It gets a lot louder now when hitting a bump, right and left off center entry in the driveway and making turns and even breaking at a stop light. It is just so annoying now. All these are my nightmares now only after deciding that since owning my Tacoma in 07 I never had the front wheel bearings replaced after hearing humming sounds in the front while driving. All shake tests for play done and couldn't replicate my issues. Tried to video while pushing up and down on the truck but could not visualize a play anywhere! I even checked the struts, mounts and bushing on the front but I could not pinpoint the exact location. And the possible culprit, the intermediate steering shaft #2, is again, resurgent cause of all these noises. I did every thing already but at this point, the spending has to stop. I cannot be replacing every part only to find out later that it was not the cause of the clunking.On some forums I have read that the cam bolts were also suspects if it was not properly torqued. The fact remains that the noise is coming from the front, on the left side, as I could hear and feel the clunking but would want to explode my frustrations because it is throwing me off. The noise is directly coming from under.
    For now I still drive it--but my wife and my son, won't. They don't trust my pick up, like there was a bad vibes to it, something unlucky and sinister. But, in fairness they never complained when it was running great and roaming this earth. I therefore, submit this issue to the forum. Please advise: what am I missing here? My truck is a 2007 Toyota Tacoma SR5 Prerunner 2WD(rear) Double Cab Long Bed. No major accident involving the bumper. It is 154, 860. I have regular factory spec struts(Bilstein) and already replaced this with OEM parts. The original tires(Dunlop) I replaced with Firestone Destination LEs. My spare tires had been stolen twice but since I retrofitted locking slot with a key controlled lifting device, and reinforced by a bike chain I bought from Advance Auto Parts in MD, theft had been prevented. As to the tailgate, to prevent theft, I installed a screw based locking device to prevent theft since there was a time in 2015-2016 when, in my former workplace, we were warned by security to lock even our tailgates(for pick up owners like me) as there were reports of it being stolen here in LA. Through its lifetime it mostly was used for street driving(home to work, vise versa) but had been to Vancouver, BC, Pacific Northwest, NV, AZ, etc. on family road trips. So that's the story of my truck. I am not sure if it will be fully functional after an almost 4 month ordeal. I'm an avid DIYer who got fed up with these stealership organized robbery of the working man, selling you stuff you don't need. Money is tight right now as I am about to hit rock bottom and I need to fix this quickly.
  17. Jan 5, 2020 at 6:44 PM
    #77
    MountainMan227
    MountainMan227 Active Member
    I'm that one truck owner whos truck has all the instances where YouTubes solutions never work, this one goes for me too. Actually made the clunking twice as bad. Any suggestions ill take im extremely desperate.
  18. Jan 6, 2020 at 8:12 AM
    #78
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    What about 2, one on each side?
    Or a pic to show us what's going on with one zip tie in there, if you can get one?
  19. Jan 6, 2020 at 8:18 AM
    #79
    Taco'09
    Taco'09 Well-Known Member
    Good luck getting them in there.
    TXpro4X4[QUOTED] likes this.
  20. Jan 6, 2020 at 9:44 AM
    #80
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Perhaps smaller ones would work instead of regular size
