Does your Transmission Rattle like an old farm truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rusumes1ep5, Jul 18, 2018.
  1. Jul 18, 2018 at 1:03 PM
    Zoop
    Zoop Well-Known Member
    specter208 likes this.
  2. Jul 18, 2018 at 1:21 PM
    natural_nativ
    natural_nativ Well-Known Member
    2024 TRD Sport MT
    I have the same noise on my 17 MT. I thought I had read on here where it was normal, like @kaijac03 said. I'm like you, though. I feel like it has gotten louder as time has gone on. I believe it is the stick bouncing around. Move your stick around while parked and you'll probably hear the same sound.
  3. Jul 18, 2018 at 1:42 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    Ball joint?
    :anonymous:
  4. Jul 18, 2018 at 1:49 PM
    Thunder chicken
    Thunder chicken Well-Known Member
    NW Ontario
    ‘18 access cab manual
    I’ve heard a funny rattling on my truck some days (‘18 MT).. then I took the receiver out of the hitch.... rattle gone! I felt rather silly but.... ;)
  5. Jul 18, 2018 at 2:05 PM
    su.b.rat
    su.b.rat broken truck
    i can reproduce that sound if i quickly release the clutch before hitting a bump, but only then. yours is nuts, and obviously not normal. pure speculation now, but i also don't think anything's getting damaged. either way I'd personally be pretty unforgiving about getting that shit 100% fixed, because even if i knew for absolute certain there's no problem, i just could not drive like that.
  6. Jul 18, 2018 at 2:19 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Sounds like the slack in the driveshaft gears. With your truck off, get under it and try to turn the driveshaft side to side, it makes the exact same noise. I've never heard the noise while driving though.
  7. Jul 18, 2018 at 2:31 PM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    I had and have the same noise. Toyota found it was a loose heat shield. They snugged it all back up but a few weeks later the rattle is back. Have an appointment Saturday to fix it again.
  8. Jul 18, 2018 at 2:51 PM
    specter208
    California
    I had a TSB performed on my truck when I had my rear diff gasket replaced. I told the service advisor I was hearing howling noise at 55+mph to try to sell him my rear diff leak. I got the truck back with a replacement heat shield for the 6MT and I had no knowledge of A TSB for this existed.
    T-SB-0186-17
    http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=198235
  9. Jul 18, 2018 at 3:01 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    That is the same noise my M/T makes when going over speed bumps etc with clutch in. As you said, never does it under load.
    Maybe it's a placebo, but it seems less noisy right after I grease the driveshaft zerks :notsure:
    Edit:
    I'd also like to add that my truck has made this clank/clunk since new, and even after both my transfer case and transmission were replaced (dealer was trying to track down the drivetrain howl before the TSB came out). Not trying to rain on your parade, just adding my experience.
  10. Jul 18, 2018 at 3:03 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Sounds to me like automatic is the way to go ! :crapstorm:
    melikeymy beer and MOC221_ like this.
  11. Jul 18, 2018 at 3:03 PM
    MOC221_
    Frank
    Not on your life lol
    rusumes1ep5[OP] likes this.
  12. Jul 18, 2018 at 3:03 PM
    KBOX
    Jody
    Acton, Ontario
    Stock
    That's it! It was rattling against the exhaust pipe.
  13. Jul 18, 2018 at 4:47 PM
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    Yeah, mine makes that sound but only like when going over speed bumps. Nothing that radical.
  14. Jul 18, 2018 at 5:32 PM
    lowtiderides
    lowtiderides No peers for 50 years...
    The Sunshine State
    2018 TRD OR
    That noise sounds hollow. Not a transmission noise. I would bet money on it being exhaust, heat shield, loose shock, u-bolts... etc
    DaveInDenver, Frito and specter208 like this.
  15. Jul 21, 2018 at 2:36 PM
    #35
    rusumes1ep5
    rusumes1ep5 [OP] Member
    17 DCSB 6M TRD Sport
    Toyota Corporate followed up with a phone call on Thursday to say that they still maintain that the neutral rattle is a characteristic of all 3rd gen Tacoma, AT & MT, though, they did suggest that my case is louder than most.
    I reminded them during the call that I don't buy the characteristic story, because it's rock solid when it's cold.
    If you can get through it, I put another more elaborate video together
    https://youtu.be/pJjb3zLqAl0
  16. Jul 21, 2018 at 2:54 PM
    #36
    jay_zed
    jay_zed Well-Known Member
    16 TRD Sport 6MT, 24 TRD Offroad 6MT
    I've noticed this since new, happens all the time when coasting to a stop below 20mph on rough potholed Michigan roads. So far dealer gave the usual "it's normal" response. Interestingly enough, it doesn't happen when in 4WD
    rusumes1ep5[OP] and KBOX like this.
  17. Jul 21, 2018 at 3:03 PM
    #37
    rusumes1ep5
    Yeah, it has been there since new - not as bad - rarely noticeable, this summer it's been much different.
    That is interesting, I don't think there's a difference between 2wd and 4wd for mine, it rattles both ways.
    Toyota is continuing to look into it they're also looking into shifting issue between 1st and 2nd that their in-house tech noticed, I didn't even bring it up, but every now and then I can't get the bugger into first gear at a stop.
  18. Jul 21, 2018 at 3:16 PM
    #38
    jay_zed
    Your 1st gear issue is something which I've had on multiple MT vehicles from multiple companies. Depending on the exact orientation of all the gears when you come to a stop, it is possible that you can get a block-out, where it won't directly slide into 1st. For me, shifting back into 2nd, then into 1st again clears it up. It also helps if the truck rolls a couple inches, but usually that isn't possible because the automatic hill-hold is engaged
  19. Jul 21, 2018 at 3:16 PM
    #39
    KBOX
    Jody
    Acton, Ontario
    Stock
    Oh wow. I thought it was just me when I can't get it into gear either.
  20. Jul 21, 2018 at 3:23 PM
    #40
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Mine does this as well. Only in neutral. Sounds very similar to taking the stick and moving it left and right aggressively while not in gear. Subbed to see if there's any fix.
