Does your Transmission Rattle like an old farm truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rusumes1ep5, Jul 18, 2018.
  1. Jul 21, 2018 at 3:47 PM
    #41
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Check your Trans mounts maybe? I still think it sounds like the drive shaft. With your truck off and in neutral. Go under the truck and try to twist the drive shaft back and forth. The sound you'll hear sounds very similar.
  2. Jul 21, 2018 at 4:01 PM
    #42
    rusumes1ep5
    rusumes1ep5 [OP] Member
    17 DCSB 6M TRD Sport
    I checked drive shaft, twisting the drive shaft makes sound in the differential,not really the transmission. It's sort of the same rattle but from a different source.
    And while hitting bumps with the rear axle makes the rattle, it's definitely sourced from in front of the drive shaft, likely in front of the transfer case.
  3. Jul 23, 2018 at 6:12 AM
    #43
    rusumes1ep5
    Yeah, it happens, no big deal - funny that the dealer made it an issue haha.
  4. Jul 24, 2018 at 7:11 AM
    #44
    rusumes1ep5
    Thanks for all the replies & solid advice.
    Toyota Canada followed up by closing the case as normal operation and reiterated that the automatic transmission will rattle while coasting in neutral over rough roads.
    I knew it would go that way, so, I followed up with the shows the condition isn't there until it warms up. I don't know what that they'll do with that information.
  5. Jul 24, 2018 at 7:12 AM
    #45
    natural_nativ
    natural_nativ Well-Known Member
    2024 TRD Sport MT
    Keep us posted if there's any new updates. Mine is just as loud as yours and I'm sure we aren't alone.
  6. Jul 24, 2018 at 7:19 AM
    #46
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Sounds like the diff is banging your exhaust pipe. It coincides with the diff movement
    rusumes1ep5[OP] likes this.
  7. Jul 24, 2018 at 7:34 AM
    #47
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    I also felt it was coming from the rear end travel.
    Either way, I hope the OP gets a resolution to this issue with minimal hassle. Keep us posted man!!!
  8. Jul 24, 2018 at 7:51 AM
    #48
    rusumes1ep5
    Rear axle movement definitely causes the rattle, but it's under the middle of the truck. It might even be more prevalent when hitting bumps on the passenger side over the driver side, thats harder to say.
    At the end of the day if this is normal operation, I think anyone considering the MT should know that it comes with a factory farm truck rattle.
    I'll keep looking into it, and I'll mention it every time I'm at the dealer, too.
    bush rat and bulalo[QUOTED] like this.
  9. Jul 24, 2018 at 8:23 AM
    #49
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Might be a long shot but check the chains on the spare tire
  10. Jul 24, 2018 at 8:51 AM
    #50
    Whitetail Assassin
    Tedric
    West Virginia
    I think you shouldn’t give up man. It’s not normal. If it was, I would have been at the dealership everyday or put in the psych ward. Lol!!!
  11. Jul 24, 2018 at 9:00 AM
    #51
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    My 18 Pro M/T made more noise than that in neutral or clutch in on any rough surface. Was noisy even in gear. Drove me nuts. Was just horrible and really made me feel like the truck was junk. My 17 auto is completely silent suspension wise or drivetrain wise except over the most roughest terrain at speed.
    This was one of the main reasons i traded in my pro for the OR. To me the transmission support is too soft and as the transmission is warmed up, it softens up the bushing more and more and allows too much drivetrain slack. Just my opinion.
    Whitetail Assassin likes this.
  12. Jul 24, 2018 at 9:19 AM
    #52
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Autos are never in neutral or disengaged (clutch pedal in) though. So I have no doubt they don't experience this. Mine makes none of this noise in gear.
  13. Jul 24, 2018 at 9:49 AM
    #53
    bristleboar
    bristleboar Member
    2017 SR Auto here.
    I frequently mess with my wife and go down our road in neutral to see if we can make it into our driveway. I have never heard a sound like this. Escalate.
  14. Jul 24, 2018 at 10:09 AM
    #54
    elduder
    Van WA
    There are variables here. The AT may not make this sound even when in neutral because the transmission itself is different as well as coupled to a torque converter. I imagine that if no AT could reproduce this noise that it's likely the issue is in the MT unit itself. While the vehicle is the same AT to MT is a bit of apples to oranges in a way. If anyone can reproduce this noise with an AT I'd love to hear it, since that would help with troubleshooting the cause.
  15. Jul 24, 2018 at 11:55 AM
    #55
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Mine rattles like crazy, and as someone mentioned, the rattle is identical to the sound you get when you aggressively move the shifter from right to left. I'm thinking something is loose on top of the transmission. When I crawl under the truck and start banging on stuff, I can't duplicate the noise.
    The search continues.
    Sure is annoying, and it makes the truck sound like a POS.
    bush rat likes this.
  16. Jul 24, 2018 at 3:14 PM
    #56
    natural_nativ
    2024 TRD Sport MT
    I still believe it is related to the shifter hitting something inside the transmission housing. I'm trying to get video to upload of the sound to see if it compares. Will update when it's done.
    UPDATE:
    https://www.youtube.com/watch?v=z1COots0O2I
  17. Jul 24, 2018 at 3:29 PM
    #57
    elduder
    Van WA
    Try this and see if it sounds familiar.
    With the truck parked, while standing outside the truck with the driver door open, grab the shifter and move it left and right.
    Its pretty audible from outside the truck.
    natural_nativ[QUOTED] likes this.
  18. Jul 24, 2018 at 3:44 PM
    #58
    su.b.rat
    su.b.rat broken truck
    that information, along with everything else, should now be pushed to Toyota Corporate. after the dealer closes the case you can walk with all that and open a new one with Corporate, and they can do something about it... probably in your case a warranty extension if the FST has already reviewed it.
  19. Jul 24, 2018 at 4:28 PM
    #59
    natural_nativ
    2024 TRD Sport MT
    That's exactly what I'm talking about. Check out the video I posted in the update above.
    UPDATE:
    Here ya go. This is the best I can do with a phone hanging out the side of the vehicle. Wind noise is overpowering, but you can still hear the rattle if you listen closely. The bigger the bump the louder the noise.
    https://www.youtube.com/watch?v=NVoNUo-hjpE
    elduder[QUOTED] likes this.
  20. Jul 24, 2018 at 4:53 PM
    #60
    ShirtTucker
    2017 V6 Sport AC MT
    Lots-o-stuff
    :mad: Yup... that's the noise.
