Doesn't start sometimes
Discussion in '1st Gen. Tacomas (1995-2004)' started by MarcD, Aug 23, 2009.
  1. Aug 23, 2009 at 9:38 AM
    MarcD
    MarcD [OP] Well-Known Member
    Hey guys,
    Last night, for the first time ever, when I went to start my truck, it wouldn't start. Didn't even turn over, just a sound from what I assume to be the starter. But then I waited about 2 minutes, and it started right away. The same thing happened about 4 hours later.
    Any ideas?
    Thanks,
    Marc
  2. Aug 23, 2009 at 9:40 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    did it click?
    One click means bad starter or bad battery connection.
    Multiple clicks means bad battery
  3. Aug 23, 2009 at 10:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    It sounds more like the starter contacts are bad. Check the battery connections first though as WhatthePho stated.
  4. Aug 23, 2009 at 10:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Definately check AND CLEAN all your connections.
    Even though they're 'tight', doesn't mean they're clean and making a good connection.
  5. Aug 23, 2009 at 10:35 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Sounds like a loose or bad ground. Check and clean them all, should also be one from the block to the firewall, check and clean that one too.
  6. Aug 23, 2009 at 12:01 PM
    MarcD
    I got lucky this time - I checked all the electrical connections in the engine bay and one of them was slightly loose, problem solved... whew
  7. Aug 23, 2009 at 12:05 PM
    fletch aka
    Gary
    Left Coast
