Doesn't this sound high?
Discussion in 'General Automotive' started by coffeesnob, Sep 12, 2011.
  1. Sep 12, 2011 at 2:30 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    $139.00 to flush my wifes Honda accord's power steering fluid..:confused:
  2. Sep 12, 2011 at 6:15 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
  3. Sep 12, 2011 at 6:20 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
  4. Sep 12, 2011 at 6:20 PM
    leveltwo
    leveltwo Well-Known Member
    Dealer?
  5. Sep 13, 2011 at 2:55 AM
    coffeesnob
    VA
    well the pump is not bad they just told her the fluid is dirty and that they suck all of the old fluid out and replace it with new which I am sure provides benefits but I would think even at a dealer ( which this is) that this is pretty much 100% profit for the dealer.
  6. Sep 13, 2011 at 4:16 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    The dealer is flat rate. Book says 2 hours, they charge 2 hours, job takes 30 minutes.
    I got an email from the dealer I bought my truck from. 70 bucks and they will change my oil and filter, top off the other fluids, and rotate my tires. Their oil change, which is filter oil and multi point inspection costs 19 bucks. so 50 bucks more they give me 10 ounces of windshield washer fluid... pass.
  7. Sep 13, 2011 at 8:58 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I have never seen a manufacturer recommend a power steering fluid change. It seems to be dealer recommended quite a bit. I think that's mostly so they can charge for it. I would be wary, I can't count the times I have changed a fluid that's not been opened before and then had leaks to fix.
