Dog Crates
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rousseb, Aug 2, 2017.
  1. Aug 2, 2017 at 5:44 PM
    Rousseb
    Rousseb [OP] Member
    Does anyone have a legit dog crate setup? Something that isn't hunky built? I have two German Shepherds both between 70-90lbs. I plan on putting a cap on the bed but still want the dogs secured in a crate. Haven't been able to find many options due to the inside of the wheel wells only being 40"
  2. Aug 2, 2017 at 5:54 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Kolunatic likes this.
  3. Aug 2, 2017 at 5:59 PM
    Sig45
    Mark
    Maine
    Oh - my 70lb German Shorthaired Pointers had plenty of room in these when I had them.
  4. Aug 2, 2017 at 6:21 PM
    Rousseb
    Rousseb [OP] Member
    Looking for something that is more secure. Something like a ruff tough kennel or impact crates. The wire crates don't offer much protection in the event of a crash.
    Tacoma2020 likes this.
  5. Aug 2, 2017 at 6:31 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    If you are worried about protection in the event of a crash you should keep the dogs strapped in with a harness in the cab.
    TRDRed, SoCal_Erik, aozer and 15 others like this.
  6. Aug 2, 2017 at 6:38 PM
    TejasTaco
    TejasTaco Grab a taco
  7. Aug 2, 2017 at 6:49 PM
    BLKTRD
    BLKTRD Well-Known Member
    2013 Baja T/X DCSB
    All-Pro Rear Bumper Leer 100XQ Prinsu Toprac Prinsu Cabrac Demello Sliders US Off Road Hidden Winch (planned) Smittybilt XRC Winch w/Synthetic Rope (planned) Lightning Racing UCAs 1" Coil Spring Spacer 1" Top Plate Spacer Old Man Emu CS047R Leaf Springs w/Add-A-Leaf 1" Rear Lift Blocks w/3 Degree Offset Extended Steel Brake Lines Transmission Drop Kit Differential Drop Kit Lucas Gear Oil (Diff, Trans) Cooper Discoverver S/T Maxx (285/75R16) Gorilla Lug Nuts Spidertrax 1" spacers Infinity Door Speakers w/Tweeters Powered 8" Kicker Subwoofer Alpine Amplifier 4 x 100w TRD Quickshift Brite-Box (Simultaneous Hi/Lo-Beam Adapter)
  8. Aug 2, 2017 at 6:52 PM
    ctsnow13
    ctsnow13 Well-Known Member
    2014 Magnetic Grey TRD DCSB
    Look at gunner kennels if you're wanting safety. I would like one, but I can't spend that much money on a crate at the moment
    daveeasa, BirdHntr and rnicholls like this.
  9. Aug 2, 2017 at 6:59 PM
    TejasTaco
    Too wide at the bottom. Bad ass crate though.
  10. Aug 2, 2017 at 7:10 PM
    BLKTRD
    2013 Baja T/X DCSB
    Yep. Expensive they is. Cabelas may have compararable house-brand stuff no they give MIL discounts.
  11. Aug 2, 2017 at 8:00 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  12. Aug 2, 2017 at 8:32 PM
    psdecoy
    psdecoy Active Member
    2xl ruff toughs fit side by side perfectly. I use them to transport my two Malinois. Plenty of room and much safer than the cab.
  13. Aug 2, 2017 at 9:24 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I have 2 of the Remington kennels. One for a Beagle and one for a Viszla. I have the larger one for the Viszla and a smaller for the Beagle. In the back they fit side by side fine. If needed you can fit the larger crates for 2 Shepards. Just a heads up if you do that near the cab I'd get some piece of rubber or foam on the part that makes contact with the metal. After a few months of having the kennels in and strapped down I noticed a slight discoloration where the kennel was making contact with the bed. Easy fix though. Other than that best set up I can come up with that won't break the bank. Also I use 2 1,000 lb ratchet straps to secure the kennels. They aren't going ANYWHERE.
  14. Aug 3, 2017 at 7:51 AM
    CusterFan
    To bad you are not around southern Illinois. A nice dog box with storage on the top for $550.00 at Greenup, IL.
    Dirk Diggler likes this.
  15. Aug 3, 2017 at 7:57 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    I am yet to email Rough Tough Kennels, but I plan to bolt 2 larges together come winter time (using their kit). It'll be a tight fit, which depends how much of a gap is left between the two units after being bolted together.
    Let me know if you get an answer from them. The bottoms are tapered, and should fit between the wheel wells provided the bolt kit minimizes gap in the center.
    Only have one right now, this was from winter time.
  16. Aug 3, 2017 at 8:56 AM
    rooster32
    rooster32 Well-Known Member
    Utah
    2017 Magnetic Grey TRD OR DC LB
    5.29 gears 6112/5160 w/Dakar Hvy SPC UCA's 255/80/17 Wildpeak AT3 Nitro
    Rough Tough with Mud River insulated covers as in the post above. 2 large fit side by side and with a rubber mat, don't move at all.
    Claybird and 7r41lbr34k3r like this.
  17. Aug 3, 2017 at 9:04 AM
    psdecoy
    2 XL RTKs side by side
  18. Oct 30, 2018 at 7:55 PM
    TRDStaude
    TRDStaude Member
    Sean
    2018 Calvry Blue TRD Pro Tacoma
    17x8.5 Method NV's wrapped in 285/75/R17 General Grabber AT2's 2 inch Rough Country Leveling Kit
    Do you guys have any worry about the dogs getting cold in the winter or having issues with CO2? I have a 50 ish pound short hair Mountain Curr. I am from Wisconsin and have an 8 hour road trip for the holidays and wanna make sure my pup is good to go. I have open wire kennels as well as the tougher plastic ones. My current plan is to strap the kennel down with some blankets and what not inside to keep her warm.
  19. Oct 30, 2018 at 7:59 PM
    TRDStaude
    TRDStaude Member
    Sean
    Do you guys have any worry about CO2 or the dogs getting cold? I have a 50 pound Mountain Curr. She has short hair and we have an 8 hour drive for the holidays and I don't want her getting cold.
    kyal5 and uplandtacoma like this.
  20. Oct 30, 2018 at 10:18 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Truck looks good. Did you lift or regear it?
