Dog entry into back of DC?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kone, Jan 31, 2024.
  1. Jan 31, 2024 at 4:24 AM
    Kone
    Kone [OP] Member
    Looking at getting into a smaller truck. I have an 8 yo Labrador that is getting older and his ability to jump is obviously reduced. I have, hopefully easy, questions...
    Based on videos I saw, It looks like I can remove both the bottom and back of only the rear "40" side of the 60/40 split seats, leaving the 60 side in. Correct? If so, with the 40 seat fully out, is there enough room for a dog to safely jump in? Is there sufficient flat floor area in between the front seat and the rear floor storage for dog to safely land? Then be able to jump onto 60 seat bottom (or folded down seat back)? I know this is relative but owner's experiences would help me a lot. Thanks.
  2. Jan 31, 2024 at 4:29 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Are you talking about the crew cab or access cab?
    4 full doors or the smaller door?
  3. Jan 31, 2024 at 4:48 AM
    Kone
    Kone [OP] Member
    Crew. Full doors. Isn't that the "double cab" officially? Thanks
    cropduster78 and Schlappesepple like this.
  4. Jan 31, 2024 at 4:48 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    With the seat removed, entry will be about 6-8 inches lower. It really depends upon your dogs ability. Removing both seat pieces should only take five or ten minutes.
    Also take a look online, there are quite a few dog steps that could also assist with entry
  5. Jan 31, 2024 at 5:59 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I lift and lower my Golden Retriever out of the back of my rig to save her knees :thumbsup:
  6. Jan 31, 2024 at 6:09 AM
    cosmic65charlie
    cosmic65charlie Consumer of good times.
    Colorado
    2019 TRD OR AC
    Offroad stuff, Audio stuff, Cooler full of beer
    This is the way. Lifting or a ramp is so much better for their joints.
  7. Jan 31, 2024 at 7:01 AM
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    Same Old Dogs issues here.
    I left the seats in.
    Look on Amazon for a folding Dog Ramp, folds to 4 feet and you can stick it in the bed of the truck.
    Training is required. They learn to trust the Ramp by starting on flat ground and getting treats eventually progressively raise the Ramp by blocking it up.
    Took about a week and they went into the truck first try.
    Yes, an Old Dog Can learn new tricks!!
    BigEasy, TireFire and TreeFortRichard like this.
  8. Jan 31, 2024 at 7:30 AM
    Uninformed83
    Uninformed83 Member
    Brian
    2020 TRD OR
    Fox 2.5” w/res, 17” RRW RR7-s w/ Toyo at3s, OTT tune
    For my 12yo Aussie I just grab his waist and lift his rear for him since his front legs are fine. You could try a lifting harness, it straps to their hind quarters with a handle on top so you can pick up their ass end. Easier than hauling a folding ramp around everywhere.
    Chew likes this.
  9. Jan 31, 2024 at 7:40 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    I took the the bottom of the seat out behind the driver seat for a month. Super easy, only 2 bolts. The instructions i found to take out the back rest part seemed a little more involved so i left it in since it was temporary for me anyway. i dont think taking either part out would make much of a difference. you could pretty much do the same thing by flipping the bottom forward and leaving the back up. you dont gain too much height either, maybe 6-8 inches like others said. i have to pick my dog up into the truck since he wont jump (idk why. he's done it before but won't anymore). a ramp would be good, but take up a lot of space.
  10. Jan 31, 2024 at 9:02 AM
    ConantTaco
    Dave
    We went with the Ramp, simply because either Dog cooperates with being lifted and my wife can't lift them. With the Ramp she is independent to take the dogs by herself no problem.
    I think she paid about 75 dollars for the Ramp.
    We also have a Back Seat Dog Cover that covers the seat and forms a barrier to keep them from jumping in the front.
    TreeFortRichard likes this.
  11. Jan 31, 2024 at 9:13 AM
    RatFive
    RatFive Member
    The Mountains
    2023 TRD OR DCLB
    I spent a lot of time changing and configuring the backseat of my 2nd gen in order to accommodate my senior dog. Including using the ramp technique. Never really found anything that made sense.
    My recommendation would be to buy a harness, I use the one below and it’s been fantastic, and lift them in or just lift them up normally if they’re accepting to that - she wouldn’t let us just pick her up anymore but had no issues with the harness.
    Our dog ended up having to get dual ACL surgery a couple years ago. Not solely because of trying to get in and out of the truck, but it was absolutely part of the problem.
    I don’t let our younger dog jump into the truck anymore either.
    https://k9carts.com/help-em-up-harness/
    cosmic65charlie and Junkhead like this.
  12. Jan 31, 2024 at 11:28 AM
    CM52375
    CM52375 Well-Known Member
    Cody
    Tennessee
    2024 Smoked Mesquite Limited Tundra
    Yea I have a black lab that is about 70 pounds and I lift her up into the backseat. I have a cover that we had for a couch that wasn’t getting used and pet her sit on that when she rides with. She will jump in sometimes, but more often than not she wants me to lift her up. She will be 7 this year so she is getting up there in age but she still agile enough. She won’t jump into my wife’s 4 runner though and it’s lower than my truck. But lifting is the easiest option as I don’t have to store a ramp or anything else
  13. Jan 31, 2024 at 11:32 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    The back won't be flat, even withe seat removed unless you make a platform. The floor raises several inches under the seat bottom due to the storage there.
    BigEasy and musicisevil like this.
  14. Jan 31, 2024 at 1:29 PM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
  15. Jan 31, 2024 at 1:38 PM
    SunRunner
    SunRunner Rub some dirt on it!
    Scott
    PA
    2019 Off Road Looooooooong Bed
    I used these steps for my dog Jack. It’s light weight and I’d just throw it into the bed.
  16. Jan 31, 2024 at 1:39 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I do the same to my guy. No way I will let him jump down from the rear seats.
  17. Jan 31, 2024 at 1:47 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    These steps:
    https://www.petloader.com/
    Pick the width. Pick the height. Watch your fingers when you collapse them.
    Been using them for 25 years.
    Indestructible.
    My Dane will be using them tomorrow for his trip to physical therapy. In and out the back of a 100 Series LC
    that180guy and 530Taco like this.
  18. Jan 31, 2024 at 1:50 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    @Junkhead here is my Girl Coco. With the rear seat delete makes getting her in and out easy
  19. Jan 31, 2024 at 2:13 PM
    530Taco
    Adam
    Old Hangtown, CA
    Layla still wants to jump in and out, but she'll be 11 this year I've been making her take it easy with the steps...
    @71tattooguy the adventures of Layla and coco, but here's that step :rofl:
  20. Jan 31, 2024 at 2:17 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Fuck yeah. Brother!!! They are the best
    530Taco[QUOTED] likes this.
