Dog leg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Apr 14, 2012.
  1. Apr 14, 2012 at 2:30 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Cleaned out the dog legs. This is the curved area at the bottom of the front fender by the door. Leaves go down from the windshield and collect there. It is covered with rubber and you don't even know it's there rotting and rusting away.[​IMG] If you don't clean them out the area will eventually rust thru and you won't even know it till it's too late.
  2. Apr 14, 2012 at 2:34 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    sounds like my jeeps
  3. Apr 14, 2012 at 2:44 PM
    george3
    New Jersey
    I didn't even know about it. I was helping my brother in law clean up his Tacoma when he showed it 2 me. He said his last Tacoma rusted thru because of this so he tries to keep it clean. It's covered with rubber so you don't even know it's happening. I checked my Tacoma and sure enough it was packed with leaves. Hopefully some people will read this that don't know about it and it will help them out to avoid the problems it causes.
    kidthatsirish likes this.
  4. Apr 14, 2012 at 4:54 PM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    pics?
    Jacob99 likes this.
  5. Apr 14, 2012 at 5:19 PM
    AlexA
    AlexA Well-Known Member
    Alex
    Newport News, VA
    2012 DCSB Prerunner SR5
    pics would be swell!
    Jacob99 likes this.
  6. Apr 14, 2012 at 5:31 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What he said ^ :)
  7. Apr 14, 2012 at 5:36 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    :worthless:
    Jacob99 likes this.
  8. Apr 14, 2012 at 5:49 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Thats not a dog leg..dog legs are in the back behind the front doors, i dont think i have ever heard of the front part being called that. But yes, i just cleaned mine out a couple weeks back.
  9. Apr 14, 2012 at 5:58 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Was curious about this.
    Is there a drain for that area? When I removed my 3rd brake light I noticed a secondary "lip" behind the light that appears that it may serve to channel water that gets past the light and down the rear pillars.
  10. Apr 14, 2012 at 6:00 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Pics of the dog bunghole or its been photoshopped?
  11. Apr 14, 2012 at 7:22 PM
    george3
    New Jersey
    That's what my brother in law called it. I didn't have any idea it existed let alone the correct name. What do you call it ?
  12. Apr 14, 2012 at 7:25 PM
    george3
    New Jersey
    That is a skill I'll have to work on but apparently some people know what I'm talking about.
  13. Apr 14, 2012 at 7:28 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    I have no idea where this is other than curved area bottom by the front door. Can someone please help out with pics?
  14. Apr 14, 2012 at 8:21 PM
    george3
    New Jersey
    Open the drivers door. Go to the bottom of the lower door hinge. Go 4 or 5 inches down from there to the soft rubber molding on the front fender. Pull this out a little and you will find all kinds of debris. Take a shop vac and suck it out. Do the same on the passenger side.
  15. Apr 15, 2012 at 11:25 AM
    OffroadToy
    I found it...Thanks OP!:)
  16. Apr 15, 2012 at 11:38 AM
    george3
    New Jersey
    Thanks for posting the pic.:D I like the sign.;) That is it. Ignore at your own peril !:eek: My Tacoma is red too so if I could have posted a pic it would have been exactly what you did. Thanks again. This should make it easy for everyone else. Like "The dog did it...I swear!" under your name.
    OffroadToy likes this.
  17. Apr 15, 2012 at 11:56 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Ill be having a gander at this in the next hour or so. Thanks for the 411. +Rep.
  18. Apr 15, 2012 at 12:43 PM
    george3
    New Jersey
    If you live in a area with trees you will find leaves in the location. I think the only people that would not be effected would be in places like Phoenix or other desert areas where there are no trees. Hope it helps U out. Thanks 4 the rep.;)
  19. Apr 15, 2012 at 12:45 PM
    drtydru
    drtydru Well-Known Member
    Dru
    Oakland
    08 4x4
    Bucket seats, Variable speed wiper switch, 09 led Tail Lights, Satoshied front grill, DDM HIDs, Fog light install, Mud flaps removed, 1.5'AAL, Billie 1552, Toyotec front coilovers w/Billies, B.A.M.F welded sliders w/kickout,
    I live in the city. I pulled out so much crap it was stupid. I was very shocked. Check it once a month.
  20. Apr 15, 2012 at 12:47 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    THanx man... I did not know that this was an issue...I'm checking mine tomorrow ASAP...
