Dog Platform
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hobiecat111629, Dec 8, 2017.
  1. Dec 8, 2017 at 6:29 AM
    hobiecat111629
    hobiecat111629 [OP] Well-Known Member
    2015 Tacoma Access Cab
    I built a dog platform in the back of my AC and covered it in some indoor/outdoor carpet that matches the upholstery color pretty well. I was pretty happy with with how well it turned out, but the 3-Legged wonder is terrified of it.
    Perhaps I used the wrong carpet, but he seems to slide off of it when I stop. Any recommendations for a less "slippery" carpet or padding?
  2. Dec 8, 2017 at 7:33 AM
    Pigpen
    Dan
    Northwest Montana
    I put a dog bed back there that's big enough it doesn't move. I also used a rubber mat for the top surface so nothing slides back there.
    TacomaUSA likes this.
  3. Dec 12, 2017 at 9:20 PM
    unclebuck
    unclebuck Well-Known Member
    2nd Gen Taco
    Stock
