Doing a little Maintenance
Discussion in '1st Gen. Tacomas (1995-2004)' started by mar_ga_rita, Apr 25, 2009.
  1. Apr 25, 2009 at 8:43 AM
    mar_ga_rita
    mar_ga_rita [OP] Head of the MASTERS CIRCLE
    New Orleans
    2003 Tacoma SR5 PreRunner TRD
    BUG SHIELD BULL BAR OFF-ROAD LIGHTS 4-RUNNER FOG LIGHT SWITCH K&N EYE OF THE TIGER ON THE BACK GLASS TONNEAU COVER
    Alright.... going to do my first oil change..... got 5w-30 synthetic and a fram filter.... and I am going to check the trans fluid.... grease everything I can see.... clean the inside and wash the outside.... prob drain the brake fluid resvior and ps resvior..... anything else I should do... truck has almost 80k on her
  2. Apr 25, 2009 at 8:44 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    Sounds like a lot of work! hope all goes well and you end up soon...
  3. Apr 25, 2009 at 8:47 AM
    mar_ga_rita
    New Orleans
    I got this... going to have the hornets game on the radio... and will be done in time to watch the draft!!!!!!
  4. Apr 25, 2009 at 8:48 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    seafoam the motor, change the fuel filter....spark plugs if you havent done them, and the rear diff(and transfer case/front diff if you are 4x4).
  5. Apr 25, 2009 at 8:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nevermind. Didnt see it was a first gen.
  6. Apr 25, 2009 at 10:27 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Im about to do my rear/front diffs, and Trans. case. Switchin to Mobil 1 synthetic.:)
  7. Apr 25, 2009 at 1:44 PM
    mar_ga_rita
    New Orleans
    I am going to change the plugs this summer... along with the trans filter and rear end fluid... and I cleaned out the intake with some carb cleaner.... lot of smoke when I sprayed it in...
  8. Apr 25, 2009 at 1:52 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Has the timing belt & water pump been changed?
    Flush & fill the radiator
    Flush & fill the steering fluid
  9. Apr 25, 2009 at 1:53 PM
    mar_ga_rita
    New Orleans
    I havent changed the tbelt water pump but when I get closer to 90k I am going to change it... and the radiator and ps and brake I did today..
  10. Apr 25, 2009 at 3:58 PM
    Janster
    Jandy
    Lancaster, PA
    Double check your owners manual. For my 96 tacoma I owned, the timing belt was recommended to be changed at 60K miles.
    At 75K miles - my radiator fluid kept loosing fluid. At 85K miles, I finally realized my water pump was leaking. I had the 3.4L also.
  11. Apr 25, 2009 at 4:08 PM
    mar_ga_rita
    New Orleans
    yea the book has it at 90k
    http://smg.toyotapartsandservice.com/guides.php?v=22&y=2003&int_id=64
