Doing my 15k mile Maintenance...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoFister, Oct 15, 2016.
  1. Oct 15, 2016 at 10:47 AM
    TacoFister
    TacoFister [OP] Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    It's Saturday. LivING on Kodiak island, no Toyota dealerships anywhere so I am going to change the oil, check U-bolts, rotate tires and I was thinking of changing out the rear diff fluid. Should I change the diff fluid or just leave it? I was thinking of putting a synthetic in there. Also. What's the Tq on the wheel lugs? I have my impact good for 120 ft lbs. I changed the oil myself at 5k miles, was changed at 10k before driving through the Yukon. Now I'm at almost 16k miles.
  2. Oct 15, 2016 at 12:57 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    I changed mu diff fluid early on. Personally I don't see the point of going through all the hassle of changing it and not using synthetic. The torque spec you are looking for should be in the owners manual.
    Aussiek2000 likes this.
  3. Oct 15, 2016 at 12:58 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I torque to 90lbs.
  4. Oct 15, 2016 at 1:20 PM
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    I understand all the oils in the difs are synthetic. Also I thought that the difs weren t due untill 30,000
  5. Oct 15, 2016 at 1:25 PM
    Aussiek2000
    2016 Offroad AC
    In my truck, id rather change the fluid than have all the metal floating around from break in
    shakerhood and vinkon235 like this.
  6. Oct 16, 2016 at 3:49 AM
    vinkon235
    vinkon235 Well-Known Member
    vince
    steubenville oh
    2016 white tacoma trdor access cab
    opt7 cree series fog lights busman aux relay box viair 450c oba opt7 fluxbeam led headlights
    Royal purple at 2000 miles.
  7. Oct 16, 2016 at 7:27 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Hi guys! I have experience changing engine oil, changing shocks, brake pads and rotors but none changing diff oil.. is there a diy explanation or video of it?
    I have 10.000 miles on my truck and I feel like it's already late to change it but I would like to do it...
    Do you know when is supposed to be changed by the owners manual??
    Thanks for the help!!!!
  8. Oct 16, 2016 at 7:32 AM
    trdgentaco
    trdgentaco Well-Known Member
    Atlanta, Ga
    2016 tacoma DC OR MT, 89 sassed 4runner
    Not to late. It's super easy, just drain plug and fill plug to work with. I think it's 4qts to fill but I fill until it starts pouring out then plug it back up
  9. Oct 16, 2016 at 7:32 AM
    Aussiek2000
    2016 Offroad AC
    Pull the drain plug, let it drain, reinstall. Pull fill plug and put fluid in until it runs out.
    trdgentaco likes this.
  10. Oct 16, 2016 at 9:25 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    TO the OP I think the drain plug on the diff is magnetic??? I haven't changed mine yet tho.
    On torque lug nuts... tight enough to stay on and loose enough to get off by hand in the frozen winter time when Murphy's law strikes. I get pissed when I need to take a wheel off and the lugs are on so tight I need a breaker bar.... how would I change a flat tire without a breaker bar... in rain at night.... ??
  11. Oct 16, 2016 at 9:38 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
  12. Oct 16, 2016 at 10:28 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I recommend changing you diff oil, I did mine at 10k and based on what I found I wish I'd done like Aussie did, at 800. But better late than never.
    I also don't bother with the dealer as I don't want any stripped oil plugs or over-tightened oil filters and I avoid that first dry start by filling my filter cap with fresh oil to prevent unnecessary wear from starting with an empty oil filter cap. And I also know what has been done and done properly.
    I torque my wheel lugs to 83ft. lbs.
    For the diff oil change you will need a new crush plug washers, you can get them all from Amazon cheap.
    I used Mobil 1 75W90 synthetic for $11 bucks from Autozone, removed the spare tire from under the bed to re-fill without using a pump and torqued the plugs @36 ft.lbs.
    Hope that helps
    Cheers!
  13. Oct 16, 2016 at 10:42 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Even though its a new truck, he should definitely get in the habit of pulling the fill plug before the drain plug! You only have to make that mistake once.....
    fdbyrne and Claudiomartinof like this.
  14. Oct 16, 2016 at 10:45 AM
    aero90
    Also, just to play devils advocate here, think of all the high mileage Tacomas on the road that have never had their diff oil changed ever. I bet if you mention "differential" to a majority of Tacoma owners they will say "whats that?"
    Nobody should beat themselves up for not switching the diff fluid after 10k miles or what not.
  15. Oct 16, 2016 at 10:49 AM
    The hammer
    Good point, but if it should be stuck, I haven't met one yet that wasn't persuaded to open up that wet hole for me with a 1/2" strike tool and a hammer!
    Hope that helps
    Cheers!
  16. Oct 16, 2016 at 11:04 AM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    What fluids you guys running in the front & rear diff?
  17. Oct 16, 2016 at 11:10 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I was gonna ask the same thing, my 2015s manual says 75w-85 and there are not many choices out there.
  18. Oct 16, 2016 at 11:58 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    I was looking into this today... went to bobstheoilguy site and everyone over there says go 75w90 full synthetic, that 75w85 from Toyota is too thin and causes a lot of wear if pushing the diff hard. Maybe some truth to that - everyone that has changed it out on the Gen3 noticed a lot of metals in the gear oil.
    Redline has the 75w85 if you want to stick with stock or pay $30/qt for the Toyota version, I'm sure its a rip off...errr worth it.
  19. Oct 16, 2016 at 1:13 PM
    Aussiek2000
    2016 Offroad AC
    redline 75w-85
    shakerhood likes this.
  20. Oct 16, 2016 at 1:19 PM
    Claudiomartinof
    I was looking for the Toyota original diff oil on Amazon and its $30 per quart! That's a lot of money!!!!!!
    Toyota Genuine Fluid 08885-02506 Differential Gear Oil LT - 1 Liter Bottle https://www.amazon.com/dp/B004SL9HP6/ref=cm_sw_r_cp_api_wa-aybSQN3FM0
    Is there another more affordable option that does not bother the lsd system?? I have no idea how that works...
    I feel that I can change it but I have no clue of which type oil I have to use...
