Doing my BHLM. Glue everywhere
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Jan 3, 2011.
  1. Jan 3, 2011 at 12:24 PM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    06 Double-Cab TRD Sport 6-Speed
    I'm in the process of doing my BHLM. While taking the lens apart... the glue got all over the outside of the headlight housing.
    How do I remove that stuff once it's done?
    and how long should I wait to dry?
  2. Jan 3, 2011 at 12:37 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    maybe stick it back in the oven for a few minutes to warm it back up, take it out and remove again. I think that would work. I would wait a day for it to dry.
  3. Jan 3, 2011 at 1:08 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Wait for what to dry? You're removing as much of it as you can while its still hot/warm (w/o going too crazy and having a completely clean slate, although that wouldnt be bad if you did). trying to remove it when it hardens would be a bit time consuming and probably not even an option. Anyway, a hair dryer also works to heat up the adhesive to the point where its pliable and can be removed. Thats what I'd do for the lens cover. Use your fingers or something softer than then lense so you dont scratch it.
  4. Jan 3, 2011 at 1:22 PM
    BarefootBandit
    Too late. Messed everything up anyway.
    I decided to spray it outside and I accidentally dropped it in the snow. Then I spray painted over the snow. Now it has dripping marks and a big circle where I aimed it at. All in the most noticeable part.
    Ebay headlights here I come :[
  5. Jan 3, 2011 at 1:25 PM
    907taco
    Bobby
    Alaska
    don't give up just yet, start over............
  6. Jan 3, 2011 at 3:51 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    x2. Dont rush, you can strip it and start over if you'd like. Worst case, you try one or two more times, and if you still cant get it, chalk it up to experience.
  7. Jan 3, 2011 at 3:55 PM
    yamaha73
    yamaha73 Well-Known Member
    Royce
    SacTown
    Trd offroad prerunner
    285/65/18 nitto trail grapplers w/ xd revolvers, second air filter removed, k&n drop in, maxtrack spindle, pro comp aal, 20% tint all around, ebay halos,rigid industries led lights behind my satoshi kenwood shallow mount subwoofer in custom box, kenwood stereo, black lower valence, plus my custom cracked windshield
    ^^^^ wat they said, dont give up yet, just strip all the paint and start fresh, worst case senario you gotta get new ones so keep trying.
  8. Jan 3, 2011 at 3:57 PM
    BarefootBandit
    I just removed a lot of the paint with paint thinner and did it over. It's drying and looks perfect now.
    Thanks for the support. Pics soon.
  9. Jan 3, 2011 at 4:35 PM
    907taco
    Bobby
    Alaska
    thats what I'm talking about!!, way to get it done.!!!!! :D
    looking foward to seeing pics.
  10. Jan 3, 2011 at 4:37 PM
    907taco
    Bobby
    Alaska
    I thought he was talking about when he completed the mod and then installed it back in his truck.
  11. Jan 3, 2011 at 6:24 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    No worries man. I knew what he meant b/c it happened on one of mine (albeit in a real small strand).
  12. Jan 3, 2011 at 6:25 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    OP, nice work on sticking with it and getting it done!!
  13. Jan 3, 2011 at 7:09 PM
    BarefootBandit
    I broke off the metal piece that holds in the headlight bulb. Broke off as in the tab that holds in that metal piece broke. It's unfix-able.
    Is this really really bad?
  14. Jan 3, 2011 at 7:24 PM
    BarefootBandit
    Specifically the metal thing that is highlighted in red here
  15. Jan 3, 2011 at 7:26 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    thats the clip for the headlight bulb, its fits right back in.
  16. Jan 3, 2011 at 7:28 PM
    BarefootBandit
    Not when you broke off one of the plastic tabs that holds it. I have it sitting in my hand right now. A piece of metal, and a tab that should not be broken.
  17. Jan 3, 2011 at 7:30 PM
    lookylookitzadam
    Adam
    San Diego
    07 DC OffRoad
    LOL, well that changes my answer. I would try and epoxy the plastic back on and then you can reinsert the clip. The bulb will not stay in otherwise, unless you wanna fashion something else up to hold the bulb.
    You could also do a true HID retro, you dont need those clips then, the new projectors would have their own. :thumbup:
  18. Jan 3, 2011 at 7:33 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Time for retros!! lol. kidding.. dont try that. umm, yea, I'd say that might be bad b/c that holds the bulb steady. You might need those ebay lights now :confused::(
  19. Jan 3, 2011 at 7:34 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Beat me to the retro comment :cool:
    Anyway, yea, try some of that 5 minute plastic epoxy found at pep boys, etc. I think thats your only option and I'm not even 100% sure that it'll hold b/c that metal tab does require a bit of pressure to lock in place. But if 6 or 7 bux does the trick, its better than 100+
  20. Jan 3, 2011 at 7:39 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Thank God this guy is not a firefighter in my city....
