Doing my own maintenance and warranty?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sublime, May 7, 2012.
  1. May 7, 2012 at 4:51 AM
    Sublime
    Sublime [OP] Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Hey guys, was thinking of doing my own 60k service....oil change, spark plugs, front and rear diff fluids and maybe taking it somewhere for tranny and transmission flush!
    Will doing that work myself void my extended warranty? I had the maintenance agreement so my oil changes were beeing done by Toyota but that has ended and will start doing my own work!
    What do you guys do as far as oil changes and services?
  2. May 7, 2012 at 4:53 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    nope, keep copies of your receipts if possible and document the date it was done (I actually use the back of the manual) and you should be good.
  3. May 7, 2012 at 6:08 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Ya? Cool, good to know!
  4. May 7, 2012 at 6:19 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I do the same. I've written everything down on the inside cover of the manual. All the dates and mileage of the oil changes (including when it was switched to Mobil 1), air filter changes, diff fluids, plugs, x-fer case and ATF change.
    To the OP, if you keep your records, it won't void your warranty unless they can show that you did something wrong and that led to a warrantable part to fail (like you forgot to put oil in and the engine seized or the drain plug was overtightened and stripped)
  5. May 7, 2012 at 6:19 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    On the toyota website under the owners tab is a place you can document your own service work as well. It is easy way to keep track & Toyota can see it too. It is based on your VIN. You can see the dealership services as well.
  6. May 7, 2012 at 8:48 AM
    theredofshaw
    Reno/Sparks, NV
    not a bad idea either.
