Doing rear diff breather mod. Anything else?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dansnare, Oct 21, 2016.
  1. Oct 21, 2016 at 7:04 AM
    Dansnare
    Dansnare [OP] Well-Known Member
    2013 T/X Baja
    Doing rear diff breather mod. Anything else I should do for water protection while I'm at it?
    Not expecting to deliberately dive into major water. This is really mostly in case of flood etc. So I won't be doing a snorkel (rear diff is cheap and easy so I figured, why not).
    So given that, anything else important to do while I'm at it?
    Thanks.
    Dan
  2. Oct 21, 2016 at 7:19 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    As long as you don't plan on going diving you should be good. Maybe Dielectric grease on connectors if you're bored and maybe check the front differential hose for any cracks.
  3. Oct 21, 2016 at 7:21 AM
    Dansnare
    2013 T/X Baja
    How much water would you go into without doing anything else?
  4. Oct 21, 2016 at 7:31 AM
    monsterkx2fiddy
    I wouldn't worry tbh. I don't like pulling my carpet after it gets soaked and muddy so I limit myself to the door level. Sometime after that is door seals, transmission breather, and transfer case breather.
  5. Oct 21, 2016 at 7:35 AM
    Dansnare
    2013 T/X Baja
    So I should be good up to the doors? Not expecting to ever go higher than that, certainly.
  6. Oct 21, 2016 at 7:45 AM
    monsterkx2fiddy
    Probably a little higher. Just remember to keep a steady, slow pace in deep water and you'll be just fine.
