Doing xsmsn drain and fill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toy4060taco, Sep 19, 2022.
  1. Sep 19, 2022 at 1:18 PM
    toy4060taco
    toy4060taco [OP] New Member
    First post...be gentle!
    Have reviewed the thread regarding the "sealed" automatic transmission drain and fill. Drain and overflow plugs easy enough to find. Getting into A/T check mode doable. My issues: Fill plug remains elusive and I have the tow package with cooler do I do anything special in this case? Any input/advice/pic appreciated.
    Dave
    2015 Tacoma TRD with A/T
  2. Sep 19, 2022 at 1:25 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
  3. Sep 19, 2022 at 5:25 PM
    toy4060taco
    Found the fill plug...now do I need to do anything with the bypass on the transmission cooler (if I have one?). On a video by the Car Care Nut he shows a bypass plunger, and states that this needs to be depressed during the process but I don't seem to have one in that location he shows. Any thoughts anyone? Thanks so much!
    Dave
    Okay just rewatched the Car Care nut video, cooler bypass plunger is not applicable to a Tacoma (Tundra, Lexus, Sequoia with external xsmsn cooler only)
    Time to give it a go this weekend...:muscleflexing:
    Update: job accomplished...drained 2 qts, added 2 1/2 - no overflow! Repeated process after adding another 1/2 qt then got about 8 ozs from overflow when at at proper temp. Only touched hot cat twice before I threw my welding glove over it o_O
    Doc Samson likes this.
