Dolly Towing - DCSB 4x4 Tacoma & 26' Rental Truck
Discussion in 'Towing' started by EasyDoesIt, Jun 16, 2013.
  1. Jun 16, 2013 at 7:38 AM
    EasyDoesIt
    EasyDoesIt [OP] Not Mine
    Las Vegas, NV
    2011 Dbl Cab TRD Offroad
    Icon C/O's
    I will be moving cross country and need to tow my 2011 DCSB 4x4 Tacoma behind a 26' Rental Truck. The potential problem is the rental Dolly says that the max tire diameter is 27", my tires are stock but 31".
    Has anyone done this before?
    If the front end is strapped down tight and correctly will I have a problem because my tires are 4" (or 2" depending on your math) too tall?
    Would it help to deflate the tires to 10-15lbs?
    *The truck is too long for the rental car hauler
    **I will disconnect and secure the rear drive shaft.
    Tow Dolly Specs:
    Load capacity 4,300 lbs.
    Strap system 3-point tie-down
    Maximum width of 74 in.
    Minimum width of 42 in.
    Maximum wheel base of 125 in
    Tire diameter: 22 – 27 in.
  2. Jun 16, 2013 at 8:00 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    If the straps are long enough to reach over your tires I'd say you should be good. If you deflate the tires, they will work out of the straps sure as hell. Remember to leave the steering unlocked & check the tension frequently! Good luck!:)
  3. Jun 16, 2013 at 8:15 AM
    Brunes
    Brunes abides.
    Rotorhead
    Make sure the straps and the retainer straps fit the tire properly.
    I'm going to guess they will not...Close but not perfect and that can earn you a ticket at the min and cause a nasty accident at the max.
  4. Jun 16, 2013 at 8:19 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    is this a 2 wheel dolly? I thought we weren't supposed to tow our trucks flat/2 wheels up? is it different for the off road package?
  5. Jun 16, 2013 at 8:19 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Just pull the rental truck with the Tacoma. :p
    I have no idea, but I wish you luck with your move.
  6. Jun 16, 2013 at 8:20 AM
    WHPLSH3
    Vance
    Alberta
    He's unhooking the driveshaft
  7. Jun 16, 2013 at 8:22 AM
    Brunes
    Brunes abides.
    Rotorhead
    This. It's not ideal, but due to the rental company rules...It's a bitch and a half to get a trailer to put a pickup on. If you remove the driver shaft it prevents the transmission from spinning which eliminates the possibility of damage.
  8. Jun 16, 2013 at 8:26 AM
    EasyDoesIt
    Las Vegas, NV
    Icon C/O's
    Thanks & good call on not airing out the tires.
    I thought about that, new straps that will fit are around $50.
    Not that I want to but I do have an extra set of rims and could mount used donuts to if need be.
    I'm just looking for safe options rather than driving it separately, spending an extra $500 on fuel, and another driver.
    Keep'em coming guys.
