DOM vs. HREW for sliders
Discussion in '1st Gen. Tacomas (1995-2004)' started by dylandercole, Mar 23, 2010.
  1. Mar 23, 2010 at 10:31 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
  2. Mar 23, 2010 at 10:38 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    i always wondered about this, is either one heavier?
  3. Mar 23, 2010 at 10:45 PM
    dylandercole
    Dylan
    from what I understand the DOM isnt any heavier, it has something to do with the carbon content of the steel.
  4. Mar 23, 2010 at 10:47 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    DOM has no seams, HREW does. DOM dents, HREW bends.
    DOM is typically used in race cages do the to fact that it doesn't have a specific point for the tube to fail (compared to HREW that will fail on the seam that it was welded)
    I went with the DOM sliders. You're welding them on so they're basically going to be permanent, and the price difference really isn't much at all, so might as well go with the stronger material.
  5. Mar 23, 2010 at 10:53 PM
    dylandercole
    Dylan
    I totaly understand. (I was 99% sure on getting the DOM anyways) I was just curious how much of a difference it made.
    no idea
  6. Mar 23, 2010 at 10:57 PM
    dylandercole
    Dylan
  7. Mar 23, 2010 at 10:58 PM
    pittim
    Pennsyltucky
    Boujee Prius
    DOM stands for Drawn over Mandrel. One solid tube with uniform thickness.
    HREW stands for Hot Rolled (Electric Weld?). Basically a flat sheet that was made into a circle and welded, so the thickness isn't always going to be uniform.
  8. Mar 23, 2010 at 11:22 PM
    dylandercole
    Dylan
    that explains it better than the articles I was reading. DOM sounds like the way to go for sure
  9. Mar 24, 2010 at 9:11 AM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Actually DOM DOES have a seam...DOM starts its life just like HREW, but it has an extra step, which is where it is Drawn Over a Mandrel (DOM). This basically cold works the steel and make the crystal structure stronger where it had been weakened from the weld (difference between DOM and HREW). It also helps maintain much tighter tolerances over HREW (not something you really care about for sliders). At the end of the day, if it is only a $50 difference, then go with DOM.....for that much tubing, it would usually be about twice the price for materials, so that is a good deal. Mine are HREW and work just fine for me (however, if I could have gone DOM for $50 more, I would).
  10. Mar 24, 2010 at 9:14 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    For the extra $50, get the DOM, I wish that I did. Mine haven't bent, but since they are welded on, I should have gotten the extra insurance.
  11. Mar 24, 2010 at 9:30 AM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    Good places to buy the stuff? Dom?
