Dome and map lights won’t dim or turn off.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTyrone, Oct 21, 2019.
  1. Oct 21, 2019 at 9:02 AM
    TacoTyrone
    TacoTyrone [OP] New Member
    18’ TRD OR
    Elka Suspension, leer camper, prinsu racks, anytime cameras, ditch and bar lights, rear rack lights , bed lights etc...
    Recently I’ve Been doing some wiring of the rear bed lights to come on when the interior lights do. Now my interior lights won’t dim or go off when the truck is off, unless I turn them to off.
    any thoughts would be greatly appreciated!!
    - I did check the fuse which blow and I replaced but still not operating as should.
    - my thought is it’s the relay or the map light assembly.
  2. Oct 21, 2019 at 9:06 AM
    Shellshock
    Iowa
    Unhook what you did and see if they return to normal
    GreyBaldTaco, LivinOnEdge and daddy_o like this.
  3. Oct 21, 2019 at 9:21 AM
    TacoTyrone
    18’ TRD OR
    I didn’t get to finish wiring, so I never hooked up anything new. So it’s all back to the way it was.
    I went back thru all the changes I made And found nothing that seemed to show any issues or be unhooked.
  4. Oct 21, 2019 at 9:22 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Bad luck bud!
    If there only was a thread describing same issues....:facepalm:
    Dome lights won't turn off!
    :evil:
    Edit. Hope you can find some answers here
    GreyBaldTaco likes this.
  5. Oct 21, 2019 at 9:36 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Domes and maps are negative trigger...you got something grounded that shouldn’t be
    TacoTyrone[OP] likes this.
  6. Oct 21, 2019 at 10:02 AM
    TacoTyrone
    18’ TRD OR
    Thats what I was reading. The thing is, I didn’t run any grounds or change anything after I opened up the dome light assembly and tested the wires to it. I think the light assembly may have melted the negative which you are talking about. I’ve put back everything which really wasn’t anything taken apart.
    I’m at the dealership now as it is under warranty and trying to get them to take a look. I’ll keep you posted.
  7. Oct 21, 2019 at 10:04 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Dont be alarmed if they charge you. Warranty does not cover customer induced issues. You may get lucky and they cover it if they do not see any evidence you tampered with it, but be ready and dont throw a fit if you have to pay.
    Shellshock, HTOWN4X4 and GreyBaldTaco like this.
  8. Oct 21, 2019 at 10:06 AM
    TacoTyrone
    18’ TRD OR
    Agreed.
