Dome and Panel circuit problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kjake, Jan 19, 2020.
  1. Jan 19, 2020 at 2:13 PM
    Kjake
    Kjake [OP] New Member
    Solved
    Sleevez and mgmdclb like this.
  2. Jan 19, 2020 at 2:40 PM
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
  3. Mar 5, 2020 at 1:03 AM
    Sleevez
    Sleevez Well-Known Member
    LA / Toronto
    2017 SW TRDPro, 2000 PinkTaco
    Any luck with this issue? I have a similar experience, but it's not exactly the same. It seems to cause a short after driving in the rain or after power wash, and it seems to short when my passenger side door opens. I will try to look through the wiring again this weekend. Super odd. Also it killed the overhead console circuit board, luckily extended warranty cover it. But now it just blowing fuses instead.
  4. Mar 5, 2020 at 6:28 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Your wire harness is done for, which should be obvious since you can see burnt wires. I had something similar, but it was an isolated event, as I didn’t have anything attached. It was considered a “thermal” event by Toyota and required my entire harness to be replaced. Because you can see what the issue is, you know those wires are bad. You can replace the harness or splice the wires. If you’re under warranty, it may or may not be covered.
    Speculating here;
    My assumptions are that there was a power surge when you attached the wires. I’m also assuming, you didn’t disconnect the battery before attaching the puddle lights?
    Also, solving one problem at a time? You have melted wires, you have to address that FIRST. Until then, you won’t be able to verify what’s causing the other issues.
  5. Mar 5, 2020 at 6:31 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    The big red instructions were probably ignored.
    shane100700 likes this.
  6. Mar 5, 2020 at 6:34 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Exactly what I was thinking. Plus a 30A fuse?! They are sized accordingly for a reason. I lucked out in the dealer not just blaming my lights, clean wiring put them on my side. I’ve since added diodes just as another safety measure. My harness came to 4K! :eek:
