Dome light and parking lights only work when the key is turned on
Discussion in '1st Gen. Tacomas (1995-2004)' started by IpswichCharlie, Mar 25, 2022.
  1. Mar 25, 2022 at 3:03 PM
    IpswichCharlie
    IpswichCharlie [OP] Member
    Just bought a 2004 double cab. Love it! However, there is a curious electrical issue: the dome light and parking lights only work when the key is turned on. My guess is a ground issue but I have no idea where to start. Is there a recall I missed? Please help.
  2. Mar 25, 2022 at 3:16 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    That's normal.
    The dome light also stays on when you remove the key, open door, get out, close door. It's on a timer, turns itself off after 10 seconds or so.
  3. Mar 25, 2022 at 5:34 PM
    IpswichCharlie
    I’m not being clear…if I open the door the dome light does not go on until I put the key in and turn it on. Also, if I get in the truck and turn the parking lights on they do not go on…until I put the key in and turn it to ACC.
  4. Mar 25, 2022 at 5:38 PM
    loudboy
    loudboy Well-Known Member
    Portland, OR
    '04 4x4 TRD Off-Road Limited
    All-Pro lift, Addicted tube bumper, Revenge sliders, stuff and crap
    Are the lights using LED bulbs? I just switched mine to nice bright LEDs and they are doing the same thing. The issue comes from the LEDs drawing so little current that the normal circuitry doesn't work. There is a lot of chatter about this issue on here and other forums for older vehicles that try to use LED bulbs. A trick is to solder resistors onto the terminals alongside the bulb, but I haven't looked into the specifics of that yet.
    Wsidr1 and Dm93 like this.
  5. Mar 25, 2022 at 6:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Will the Dome light come on if you turn it to ON? (Not the door setting)
    wilcam47 likes this.
  6. Mar 25, 2022 at 7:08 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    LEDs and aftermarket alarms have both been accused of causing this in various threads.
    https://www.tacomaworld.com/threads/dome-light-questions.733314/
    loudboy[QUOTED] likes this.
  7. Mar 26, 2022 at 4:09 AM
    IpswichCharlie
    Yes, I am using LEDs in the dome lamp. I’ll switch and see if it works. What about the parking lights?
    Thanks for the help
  8. Mar 26, 2022 at 9:12 AM
    IpswichCharlie
    Wow! It worked…I installed an incandescent bulb and it is working properly!
    Thanks for the advice
  9. Mar 26, 2022 at 10:01 AM
    ijm01PR
    ijm01PR Well-Known Member
    Alex
    Indiana
    01 DC Prerunner (4x4 TBD)
    Ome 881s w/ 5100s and jba ucas 2” pro comp AAL with 5100s in the rear
    If you swap for leds, you have to get canbus leds in order for the lights to work without the key being on. At least that’s how it worked in my 01 double cab.
