Dome light bulb - recommended bulb is too big
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deeman, Aug 1, 2020.
  1. Aug 1, 2020 at 10:29 AM
    Deeman
    Deeman [OP] Well-Known Member
    Columbus, Ohio
    2003 Toyota Tacoma RWD Base Model 5 Lug
    Nerf bars and topper
    I have a base model 2004 with the small dome light right up near the windshield / rear view mirror.
    It does call for a 3175 bulb which seems like it would work but it seems like a 3175 is a bit too long to fit into the bulb terminals. It's just a tiny bit too big and I tried smashing the terminals to be a bit more open to accommodate the bulb, but it just does not fit.
    I tried both a LED and conventional bulb and its the same for both.
    Is this a common issue? Am I missing something?
  2. Aug 1, 2020 at 10:33 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    the bulb should fit into grooves that are on each side of the contacts. unless yours does not fit inside the housing at all?
  3. Aug 1, 2020 at 11:44 AM
    Deeman
    Columbus, Ohio
    You are correct, that worked. It was really tight but it fit. Thanks!
  4. Aug 1, 2020 at 3:24 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    :thumbsup:
  5. Aug 1, 2020 at 6:36 PM
    Dylwhit
    Dylwhit Well-Known Member
    Dylan
    2004 2.7l extcab
    I just popped in my 04 and it took a little muscle. Maybe thats why they sell em in a two pack! Hah
  6. Aug 2, 2020 at 9:21 AM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    which Leds did you use? did it work?
  7. Aug 2, 2020 at 5:02 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I ended up getting mine from @csjumper2003 due to his including the resistors on them. otherwise there is not enough draw in the 01-04 to keep a single one on.
    jrallan26 likes this.
  8. Aug 2, 2020 at 5:25 PM
    Akkording
    Pete
    Houston
    right on yeah thanks for informing me of the seller
  9. Aug 2, 2020 at 8:47 PM
    Akkording
    Pete
    Houston
    @csjumper2003, hook me up with two pairs please. pm your payment option, hopefully you take paypal
  10. Aug 2, 2020 at 10:14 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    No problem. Pm incoming.
  11. Aug 6, 2020 at 7:24 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    csjumper to the rescue!
