dome light doors ajar come on randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undersc0re, Jan 19, 2013.
  1. Jan 19, 2013 at 2:03 AM
    undersc0re
    undersc0re [OP] Well-Known Member
    BC Canada
    exhaust and k@n filter setup.
    It used to happen rarely, but its getting worse now. Iwill turn the steering wheel and the doors ajar dash light comes on as well as dome light. I make a slight move with steering and it goes out. Also I am driving straight and turn the heat/cool fan on it the lights come on sometimes as well, more often when it is in the high speed mode, then when I turn fan off the lights almost always go out...So far those two seem to cause the lights to come on whether seperately or together....weird. I thought maybe someone would figure this out right away here, I was thinking maybe wires rubbing on steering column or bad battery....but who knows...everything is stock on it.
    Thanks!
    When it first started, it was only once in a while when making a turn, then it would come on for a sec and go away right away...very rarely, and I think only when I first started the truck in the morning and drove first 5 min....
  2. Jan 19, 2013 at 2:10 AM
    acdronin
    acdronin Well-Known Member
    Poltergeist, you need a priest, not a mechanic
  3. Jan 19, 2013 at 8:56 AM
    undersc0re
    BC Canada
    LOL thanks, I am gonna get the thing checked out next week, I just don't want to pay hundreds of dollars for some guy to test everything and poke around...I just turned the dome light off so it doesn't come on by itself in the middle of the night, but the dash light comes on...hopefully the red dash light won't kill my battery!
  4. Jan 19, 2013 at 10:41 AM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    It's possible one of your doors is out of adjustment or one of the switches is whacky. Have someone push and pull on each door without touching the handle as you watch the dash light to find the culprit.
  5. Jan 19, 2013 at 10:45 AM
    Vstrom30
    Midwest
    The body flexes when turning and going over bumps and the doors move slightly so one if the door switches is being disrupted.
  6. Apr 13, 2015 at 5:37 AM
    bwanamukubwa
    bwanamukubwa Well-Known Member
    Tennessee
    Did you resolve this problem? I'm having the issue on right turns only. Thanks for your feedback in advance.
  7. Apr 14, 2015 at 8:29 AM
    undersc0re
    BC Canada
    I think I did, i am not sure which door is usually the culprit, or which switch is most sensitive, but I open all the doors including the extended cab doors and then give them a good slamming shut, it fixes the issue as far as I have noticed lately.
  8. Apr 14, 2015 at 8:34 AM
    bwanamukubwa
    Tennessee
  9. Apr 14, 2015 at 8:37 AM
    Pigpen
    Dan
    Northwest Montana
    I'm guessing the piece your door latch clips to is worn. I think it can be rotated 180 to fix this. If it can't, it should be an inexpensive part to replace. This is assuming you have an older truck. I don't see your year listed.
    Slamming could lead to other problems...
  10. Apr 14, 2015 at 8:40 AM
    bwanamukubwa
    Tennessee
    it's a 2010, but i appreciate your input and will check this before slamming anything of course..
  11. Apr 14, 2015 at 8:59 AM
    Pigpen
    Dan
    Northwest Montana
    Was referring to Op, but hope you get it resolved too bwana
