Dome light LED bulb that actually works right.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco me elmo, Feb 3, 2012.
  1. Aug 28, 2018 at 7:08 PM
    #201
    bee.deej
    bee.deej New Member
    2001 DoubleCab
    If you turn on the front map light does that make the dome light full brightness? I have the same issue with mine. That is the only temporary fix I have found. It happened even when I was using the OEM bulb so i don't think it is an led issue
  2. Aug 29, 2018 at 12:16 PM
    #202
    snotaco
    snotaco Well-Known Member
    Lewiston, Idaho
    2003 prerunner tacoma
    2003 tacoma double cab, prerunner, 4wd conversion, 5 speed conversion, dual cases with inchworm clockable adapter, toytec ultimate coil overs, trd supercharger with urd 7th injector, 37 inch mastercraft mxt's, arb front locker
    this is going to sound a little sketchy, but i have all led in the map lights and dome light and got tired of it not lighting up right. my fix for the issue was putting the stock bulb back in the dome light, under the led panel i had in there. that way the light is working normal and getting the right resistance, but hidden and the led is shining in the cab.
  3. Aug 29, 2018 at 11:25 PM
    #203
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    This is what you need to use people.
  4. Aug 30, 2018 at 12:14 AM
    #204
    1HItaco
    1HItaco Well-Known Member
    or just check out this guy!
    https://www.tacomaworld.com/threads/jumpers-leds.176932/
    he sells plug and play units with the resistor already connected to the LED!
    i had the same problem with my dome light not going to full brightness until i turned on the ignition.
    after i purchased a set of lights from jumpers led's my dome light is at full brightness when i open the door again. just like factory
    04 1st gen DC!
    forum says for 2nd gens but shoot him a PM and you will reveive LED's that actully work!
    Fernando and jammer like this.
  5. Aug 30, 2018 at 7:35 AM
    #205
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Yep, that's what I did. I've purchased the dome / map lights from Chris about 2 years ago and they are still going strong.
    Tacoma World member csjumper2003
  6. Apr 19, 2020 at 1:23 AM
    #206
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
  7. Apr 24, 2020 at 4:43 AM
    #207
    2001busa1
    2001busa1 Member
    Sam
    New York
    2013 Tacoma 4x4
    None yet
    This thread is probably prehistoric but I’m having a flickering issue with front amber corner marker lights. They were great for a week then last night both of them started flickering. I took one out of the headlight housing and noticed it was hot so I blew on it and the flickering slowed down so I let it cool for a minute and it stopped. Then I let both of them cool and they stopped blinking. About 10 seconds after putting them back in the housing where there’s no cool air they started flickering. Are they all going to do this or do I just have a crappy set of bulbs??? They’re the imitation LASFIT leds. I didn’t think it was a big deal when I ordered them but maybe It was??
  8. Apr 24, 2020 at 4:45 AM
    #208
    tony2018
    tony2018 Well-Known Member
    Check with manufacturer support.
  9. Apr 24, 2020 at 8:35 AM
    #209
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Probably crappy LEDs getting to the end of theirs life. Some LED bulbs (with fancy driver built in) have a heat protection built in the driver. Depends on the driver some may go dim when hot other will cut off (flicker). So when bulbs are flickering in normal use it means the driver is going out (overheats and trigger thermal protection).
  10. Dec 26, 2020 at 11:14 AM
    #210
    Toddb63
    Toddb63 New Member
    Todd
    2002 Tacoma Prerunner
    thanks for all the comments and support, i been reading this thread and decided to give it a try, what the heck there pretty cheap anyway. So i taught myself how to solder, bought some 100 ohm 1 watt resistors and i can say without a doubt in my 2002 tacoma prerunner that this works 100 percent. I now have blasting dome and map lights working with the key off. Thanks to everyone for there input i would never have figured this out alone. This has been one helpful thread
