Dome light LED bulb that actually works right.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco me elmo, Feb 3, 2012.
  1. Jun 21, 2013 at 10:21 PM
    #141
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Agreed. I worked for them in the late 80s when they were transitioning from the "brown" to the gray "tech" store style.
    In those days, they still had multiple 4ft sections dedicated to components, and a fair stock of each.
    They started falling apart in the 90s and by 2000 were worthless for parts. What they carried was low quality crap, but it didn't matter because they rarely stocked more than two of each item, but never actually had them in stock because the parts were always in the wrong bins so they never got ordered.
  2. Jun 24, 2013 at 5:34 PM
    #142
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Just got my 100ohm 3 watt resistors in the mail today. The guy at Talon was super quick to ship them. I'm going to hopefully get around to putting them in tomorrow. They certainly don't look like the little pansy ones that RadioShack sells.
    59158DD5-9F9B-4915-BD47-89B863637A65-939_69f61058957f86012354317b978ff725a785c025.jpg
  3. Jun 25, 2013 at 4:26 PM
    #143
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Got them soldered on. I had to mount the resistors for the map lights on the sides because there wasn't enough room to put it on top, it would touch plastic parts. I used 1 resistor for each light, works like a charm! No key on acc needed. The resistors do get pretty hot, but I'm hoping that the 1/8" gap between the resistors and other plastic/objects will be enough. And the resistors since they're rated at 3watt should be able to handle the heat just fine. The dimming function works fine also.
  4. Jun 25, 2013 at 4:51 PM
    #144
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Adding resistors kind of defeats the the low current draw of an LED doesn't it. Or are you just looking for more light?
  5. Jun 25, 2013 at 5:03 PM
    #145
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Well, considering we're talking about 2 watts for each light, it's not a big deal to me. The main thing is brighter, crisper light... And never having to change another one of those bulbs ever again.
  6. Jun 25, 2013 at 10:42 PM
    #146
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Also, I have three resistors left. I bought 6 in case I needed to use more than one on each light (I didn't).
    If you want to get the ones I have leftover, shoot me a PM.
  7. Jun 26, 2013 at 4:35 AM
    #147
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I guess that's my point with the resistors your now at 5 watts per. If the effect is more light I can understand that. Guess changing bulbs once every 10 years can be trouble sum. If you guys have a broken tail light it's full of 3 watt resistors for the stop/parking light LED's
  8. Jun 26, 2013 at 9:08 AM
    #148
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    5 watts per? I think it's more like 2.7 watts per. I'm not going to cry about 2.7 watts when I have a 500 watt amp and a 180 watt LED bar also.
    And yes, as I said before, more light.
    As far as brake light LEDs, that's a matter of safety for me, not form. LEDs fire on faster thus alerting the driver behind you faster. Too many dumbasses on the road where I live. If my tail lights say "hey dumbass, I'm STOPPING," then good. I've been rear-ended one too many times in my truck.
    If you're here to throw your opinion around, you're entitled. That being said, everyone has one and they all smell like an assh*le. I don't really know what other point you're trying to make.
  9. Jun 27, 2013 at 4:52 AM
    #149
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I'm not trying to make any point just wondering why one would go to the trouble with some thing that gets used rarely. LED stop lights etc. make a great deal of sense as all of their light output is facing the right direction.
  10. Oct 17, 2013 at 7:28 PM
    #150
    amp3d
    amp3d Well-Known Member
    Mark
    Toronto
    2002 Double Cab TRD Offroad, 2012 Access Cab
    thanks folks for this thread, it's been very helpful!
    I just ordered my LED for the dome but while I'm waiting on its arrival I thought I would see what resistors that you recommend?
    Everyone seems to have a different idea of which resistors are ideal, 100ohm 3w? 1w?
    Thanks, and sorry again for bringing back an older thread!
  11. Oct 17, 2013 at 7:29 PM
    #151
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    100 ohm 1w for the 01, 02, and 04 models
  12. Oct 17, 2013 at 7:48 PM
    #152
    amp3d
    Mark
    Toronto
    perfect, thanks!
    No heating issues?
    Not that it matters, but do the LEDs still dim when we shut our car doors?
  13. Oct 17, 2013 at 7:57 PM
    #153
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    i picked mine up from ebay for like 3 bucks.
    came from china. works fine.
    sometimes its dim, but if i smack the light, or even roof around light, it pops up all bright like. leasds me to believe bad connector. might look into running two builbs, the normal yellow AND an led, so you can actually have the correct resistence.
    maybe put the yellow bulb in the glove box so when doors are open the glove box has light to dig around, or maybe footwell. just have to find the wire in the harness which shouldnd be to bad. i recall "DOME" having its own fuse, i think.
    The dome fuse in my 99, also controls the always hot wire that runs to the radio that keeps your time. so you could even trace it back from there. just add a little resistance.
    But that leads us to, is your stereo aftermarket? is the pull for the clock correct?
    sub edit, do note that the DE3022 is different then the DE3022LL, different length that is. that being said the opposite is whats used int he door lights. which mine are LED. freakin bright without covers, with covers, meh, take it or leave it.
  14. Oct 17, 2013 at 8:02 PM
    #154
    csjumper2003
    Savannah, GA
    The pre 01 doesn't have the issue that they are talking about.
  15. Oct 17, 2013 at 8:03 PM
    #155
    csjumper2003
    Savannah, GA
    I put them on the back of the led before I ship them. That way they are plug n play for the customer
  16. Oct 17, 2013 at 8:04 PM
    #156
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    gotcha. so my solution would still work then. just provide a resistor, or a bulb.
    ive had poor luck with autozone inline resistors, yet dont wanna spend much on sealed resistors, so the second bulb is probably the best way.
    i have seen leds that provide "stock level" resistance, but are usually 20+ bucks.
  17. Oct 17, 2013 at 8:08 PM
    #157
    csjumper2003
    Savannah, GA
    a single 6 led 31mm dome for the application I sell for 15. They work great, but you are correct the hot lead is where you can add resistance. I add it behind the led so that you never know is there and will work great. no heat issues
  18. Oct 17, 2013 at 8:16 PM
    #158
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    how much resistance?
    at op, resistors can be had from your local radio shack. unless yours is like mine. they only sell cell phones and prepaid phone cards. and tv's now :(
  19. Oct 17, 2013 at 8:31 PM
    #159
    csjumper2003
    Savannah, GA
    100 ohm 1 watt for 01,02,and 04 models
  20. Oct 17, 2013 at 8:34 PM
    #160
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Why not 03 models?
    slickyd likes this.
