Dome Light Mod / Map Light Mod.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DeeKay21, Feb 11, 2009.
  1. Feb 11, 2009 at 11:15 AM
    DeeKay21
    DeeKay21 [OP] Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hey has anyone here done the Dome Light mod / Map Light mod? Or even if you haven't. I'm trying to figure out how to pop out the whole front section where the temperature-sunglass-maplights are located. I know there's a screw you have to take out where the sunglass holder is but how do you get the rest of the whole piece off?:confused:
  2. Feb 11, 2009 at 11:18 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    To remove that console, pull from the rear. You'll have to be firm with it because there are a couple of metal clips that have to pop loose. But, don't pull from teh front or you'll tear your headliner. There are two forward facing hooks that hold the front in place.
    Make sense?
  3. Feb 11, 2009 at 11:23 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay that's what I've heard. Now when you say rear, do you mean the part closest to you and farthest from the front windshield? Or rear as in part closest to the front windshield? Also, just pull straight down right?
  4. Feb 11, 2009 at 11:26 AM
    LonghornTaco
    Minnesota
    Yeah, the rear is the part farthest from the windsheild. And pulling down is the proper direction to make the clips release.
    And if memory serves, the clips to release are towards the front of the console, so you may have to pull down with equal pressure on the sides a little too...
  5. Feb 11, 2009 at 11:27 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay got yah!!! Thanks Longhorn!!! Let me go try it out!!!;)
  6. Feb 11, 2009 at 11:30 AM
    LonghornTaco
    Minnesota
  7. Feb 11, 2009 at 1:20 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay I got it off. Oh and you have to pull down the very front of it, "closest" to the front windshield where the temperature display is.:cool: That's where those to metal clips are.;)
  8. Feb 11, 2009 at 1:26 PM
    LonghornTaco
    Minnesota
    Oh shit! Are those clips that hold on to the headliner at the back of the console???
    Been a while since I took it out...
    Sorry dude! :eek::boom:
  9. Feb 11, 2009 at 1:33 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Haha! No worries. It took me a bit and kind of screwed up a couple of clips but it was all good. Just popped the clips back into place and it was okay. Ran the ground wire to the dome light. Still have to connect it to the dome light but my shift was about to start so I took off and left it hanging.
  10. Feb 12, 2009 at 9:02 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Where and how do you connect it to the dome light? It was king of unclear from the final pic in the write up. I took my dome light down, do you just need to add a ground to the dome light with a bolt?
  11. Feb 12, 2009 at 9:09 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    You know what I tried eveything but I can't figure it out!!! I'm thinking of putting it back to stock!!!:eek: But yeah you just add a screw and a blot to hold it in place. Let me know if you get it to work!
  12. Feb 12, 2009 at 2:50 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay if anyone wants to do this mod, I found a much, much, much easier way to do it without a diode. And about 1/4 of the time too!!!:D Actually, harshest found the info but I put it into action and it worked great!!!:eek: Thanks again harshet!!!
  13. Feb 12, 2009 at 4:09 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    What did you end up doing?
  14. Feb 12, 2009 at 4:12 PM
    LonghornTaco
    Minnesota
    Yeah, quit being a tease you little bitch!
  15. Feb 12, 2009 at 7:37 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Well like it says in the steps on the mod, switch the two wires on the map light connector. Don't worry about any saudering or diodes, connect the ground on the "dome light" just like the picture with a screw and bolt and a spade connector for the ground wire. Then run the wire back to the map light connector, strip wire back on the ground wire and place in the 3rd section of that connector! Re-connect to map light and it should be good to go!!!;)
  16. Feb 13, 2009 at 7:55 AM
    harshest
    Michigan
    05 PreRunner SR5
  17. Feb 13, 2009 at 8:00 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
  18. Feb 13, 2009 at 8:05 AM
    harshest
    Michigan
    05 PreRunner SR5
    Tomorrow afternoon, I'll let you know how it goes.
  19. Feb 13, 2009 at 8:13 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah it's super easy!!!:D
  20. Feb 14, 2009 at 9:20 AM
    harshest
    Michigan
    05 PreRunner SR5
    :thumbsup:
    I ended up soldiering it to the dome light because I didn't have a small enough bolt. Regardless it works without the diode.
    Next I am going to figure out a DTRL mod that uses the brighter out the two filaments without buying the parts from Toyota.
