Dome light no power unless key ignition is on.
Discussion in '1st Gen. Tacomas (1995-2004)' started by derelique, Jun 21, 2021.
  1. Jun 21, 2021 at 4:51 PM
    derelique
    derelique [OP] Well-Known Member
    Derek
    2004 Tacoma
    I have an 04 and confirmed no voltage or power is hitting the dome light until I turn on ACC. I know there are several fixes for fixing the dome light by cleaning the terminals. I tried that first then put a voltage meter on it to confirm it's not getting power at the plug(removed light assembly) until ACC is on.
    Anyone else have this problem at all?
  2. Jun 22, 2021 at 11:11 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    If you have LED bulbs, the system gets wonky! If you are using LED, you need to add a resistor to at least one of the bulbs (either dome, or maps, if you have them)
  3. Jun 22, 2021 at 1:26 PM
    Diemaster
    Diemaster Active Member
    Josh
    San Bernardino
    2004 SR5 Tacoma 4x4 V6 Double Cab
    I have this problem too. I had LED's in for a while and the system worked just fine, then one day, just as OP said, only on ACC will the dome light work. I tried switching back to normal light bulb and tried CAN LED bulb (with built in resistor) problem never went away.
  4. Jun 22, 2021 at 4:58 PM
    derelique
    Derek
    2004 Tacoma
    I did have a non LED bulb and replaced it with a LED originally thinking it was out. So both are doing it.
  5. Jun 22, 2021 at 5:44 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    so when you have it set to "door" and open your door you get no power to dome light?
    might be something with the "courtesy" light function
  6. Jun 24, 2021 at 10:15 PM
    derelique
    Derek
    2004 Tacoma
    Correct. Only works when the key is in the ignition and either on acc or the truck is running.
  7. Jun 24, 2021 at 11:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What happens if you turn on one of your map lights?
  8. Jun 25, 2021 at 4:54 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Have you tested the door switch sounds like it is no longer working!!
  9. Jun 25, 2021 at 12:17 PM
    derelique
    Derek
    2004 Tacoma
    I think the door switch is good. It works with ignition on like it’s supposed to.
  10. Jun 25, 2021 at 12:20 PM
    derelique
    Derek
    2004 Tacoma
    I will have to check. I think those turn on and off like they should.
  11. Jun 25, 2021 at 3:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The question would be, do they turn on the dome light (when the dome light isn't on but should be on) when you turn one of the map lights on.
  12. Jul 29, 2021 at 9:04 AM
    derelique
    Derek
    2004 Tacoma
    Confirmed the map lights work as they should. No key in the ignition and they will turn on. The dome light only works as it should when the key is in the ignition and acc is on or the truck is running.
  13. Jul 29, 2021 at 9:32 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    then I concur with @Wyoming09 and @Digiratus that it is the door switch or the dome light housing/switch that is bad
    turning the key on in the ignition is it's own function, it sends power based on ACC and will work if the dome light is set to ON. It will not work if it is set to DOOR and the door is closed as it's designed to think you are already in the vehicle and ready to go. It should turn on when you turn off the truck and open the door.
    when I set my dome light to DOOR if I unlock with remote or with key, before I even open the door, the dome light comes on
  14. Jul 29, 2021 at 9:54 AM
    derelique
    Derek
    2004 Tacoma
    I may have not explained it correctly above. It does function as it should only when the ACC is on. Door open: it comes on and when I close the door: it turns off.
    That’s telling me the door switch is good and it has to be something else. I’m not an expert mechanic though.
  15. Jul 29, 2021 at 10:10 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    sounds correct. I think there is another part that operates alongside the ignition switch but I'm not sure where/what that would be
  16. Jul 29, 2021 at 11:51 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Sounds like the courtesy light timer is not functioning.
    The door switch activates the timer which turns light off 30 seconds after closing door with key removed from ignition.
  17. Jul 29, 2021 at 12:06 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Have you confirmed the 15A dome fuse is good?
    Power goes from the dome fuse to the Body ECU. The body ECU is what controls when the light comes on.
    I have attached the wiring digram from an 03, but it should be the same for 04.
    The diagram shows that the Body ECU is powered by the IGN Fuse, so it's possible that you are only getting power to the dome from the IGN circuit and not dome.
    I don't have the internal wiring for the Body ECU, but it's worth a check.
  18. Jul 29, 2021 at 1:04 PM
    derelique
    Derek
    2004 Tacoma
    Awesome, thank you! I will check that out soon.
  19. Mar 16, 2024 at 9:16 PM
    davep_2001
    davep_2001 New Member
    David
    2001 Toyota Tacoma
    I had the same problem- caused by using LED in the Dome light - switched back to incandescent and everything works great now
