DOME LIGHT NOT WORKING
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DIRT TACO 16, Dec 29, 2016.
  1. Dec 29, 2016 at 4:30 PM
    DIRT TACO 16
    DIRT TACO 16 [OP] Well-Known Member
    Greg
    2016 TRD OFF ROAD 4X4
    AIR CONDITIONING DRAIN EXTENSION
    Just had the rev 1 reflash done last week and finally drove the truck after dark, noticed that my dome light does not work. Map lights work.
    1. could the reflash have done something.
    2. dont the fuse that works the map lights also control the dome light.
    3. Checked no power running to the dome light.
    Any ideas.
  2. Dec 29, 2016 at 4:32 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Check the fuses
  3. Dec 29, 2016 at 4:37 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Switch in the off position at the light too?
    shakerhood likes this.
  4. Dec 29, 2016 at 5:15 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Check the switch
  5. Dec 29, 2016 at 8:34 PM
    DIRT TACO 16
    Greg
    ill have to test it out on sat. On the fuses does the fuse that says dome 7.5 control the map lights also or does it use another fuse. If it uses the same fuse then the fuse is good, because the maps work fine.
  6. Dec 29, 2016 at 11:08 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    This.
    It's common practice to shut off unnecessary accessories when doing diagnostics.
    shakerhood and Herniator[QUOTED] like this.
  7. Dec 30, 2016 at 11:13 AM
    DIRT TACO 16
    Greg
    thanks ill swing by the dealer and have it checked,
  8. Dec 30, 2016 at 11:43 AM
    Shellshock
    Iowa
    Oddly enough mine just did this last night too. I havent spent the time looking at fuses yet but did check the switch and I couldn't turn it on or have it turn on with the doors. Map lights worked. I don't believe any of the lights turned on when I came up to it with the keyfob or unlocked it.
    It's on the list of stuff to do this weekend. Hopefully it's nothing major.
    davidstacoma and shakerhood like this.
  9. Dec 30, 2016 at 2:11 PM
    DIRT TACO 16
    Greg
    Good Luck i will post as soon as i find out something. Has anyone else had this problem.
  10. Dec 30, 2016 at 4:39 PM
    splitbolt
    NW Arkansas
    Maybe the reflash deleted all your customization.
    wahoobie likes this.
  11. Dec 30, 2016 at 4:47 PM
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    They did this to mine when I had the TSB done. My wife noticed before I did :anonymous:
    davidstacoma likes this.
  12. Dec 30, 2016 at 7:49 PM
    jluu44
    jluu44 Well-Known Member
    Jon
    North County San Diego, CA
    2016 Tacoma DCSB 4x4 off-road
    Same thing happened to my truck the other day. Dome light didn't work, but map lights still work. :confused:
  13. Dec 30, 2016 at 9:00 PM
    DIRT TACO 16
    Greg
    Ok feel stupid, the rocker switch between the map lights was turned off must have hit it which kills the dome light.
  14. Dec 31, 2016 at 8:50 AM
    Shellshock
    Iowa
    Oddly enough… mine was the same thing. It looked like it was in the right spot but must have got bumped and been just enough to turn them off. Flipped it on and off and everything is working again.
  15. Dec 31, 2016 at 12:34 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    As Homer would say...."DOH.."..:facepalm:
  16. Dec 31, 2016 at 12:39 PM
    Herniator
    Edmonton
    I hope you didn't go to the dealer to figure that out.
  17. Jan 2, 2017 at 4:24 PM
    DIRT TACO 16
    Greg
    No noticed it at night time with the lights on.
    Herniator likes this.
  18. Jan 4, 2017 at 6:17 AM
    mangler
    mangler Well-Known Member
    Saskatchewan, Canada
    1998 Tacoma 4x4
    My dome light has not been turning on. Discovered it is the rubber over the door switch. They don't like working when it is -30 celcius, cock stiff and won't turn my interior lights on, anyone else have this problem ?
  19. Jun 30, 2019 at 6:42 AM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Can't tell you how much trouble you saved me. I just installed so many electronics I was seriously thinking I damaged a wire in the loom.
  20. Sep 17, 2019 at 6:20 AM
    K-Bear
    K-Bear Well-Known Member
    2017 Inferno DCSB TRD OR
    So I'm having a problem since installing Meso puddles (which are also currently not functioning). The maps and dome both are not working. Really hoping I didn't damage a wire in running the harness. Any ideas? I have messed with all the switches I can think of.
