Dome light on non dimming Tacoma’s.
Discussion in 'Lighting' started by Caslon, Dec 15, 2021.
  1. Dec 15, 2021 at 10:36 PM
    Caslon
    Caslon [OP] Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Every post is how bright you can get light to shine. My humble 2003 dome light wants the best of both worlds (bright and not so), without installing an aftermarket dome assembly. I am working on a zany DIY solution. A clip attached to the dome cover that allows sliding in small thin square “shields” with varying degrees of opaqueness. Colors even. Some jazzed by the source light, that they even change colors! Laugh if you want. I’m gonna try and come up with something simple without having to buy and install an after market dome light assembly. Slides could even be a photo, illuminated.
    Deaf ears probably. Still gonna work on it. Comedy relief too, probably.
