Dome light only comes on when map lights are turned on?
Discussion in 'Technical Chat' started by moto932, May 1, 2011.
  1. May 1, 2011 at 9:38 AM
    moto932
    moto932 [OP] What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    the other day my dome light stopped working. i just thought the bulb burnt out so i ordered on from super bright leds and i go to take the factory bulb out and the filament looks fine. so i put in my new led and get nothing. after messing around for a awhile i went to turn on my map lights so i can see, and to my surprise, the dome light lights up like a christmas tree. turn the map lights off and the dome light goes off. this is all with the doors open and the dome switch on "DOOR" but it's the same way when i switch it to "ON".
    any ideas on what is going on??
  2. May 1, 2011 at 11:53 AM
    moto932
    Eric
    Dayton, Ohio
    04 TRD Off Road
    dome light also comes on when: map lights are turned off, door open, and key turned on in ignition.
  3. May 1, 2011 at 12:07 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Gremlins?
  4. May 1, 2011 at 12:21 PM
    Average JOE
    Average JOE Well-Known Member
    San Diego
    PreRunner
    3'lift,Upgraded sound system,Dyanamat interior flowmaster,K&N,
    Enjoy it. I have heard some members asking how to do that. Maybe you could do a write up on it! JK
  5. May 1, 2011 at 5:18 PM
    moto932
    Eric
    Dayton, Ohio
    04 TRD Off Road
    i looked and didnt see any :notsure:
  6. May 1, 2011 at 5:21 PM
    MHS2846bg8
    MHS2846bg8 Experienced Noob
    Nate
    South Coast of Oregon
    21 Tacoma TRD Off-Road Dbl Cab 4x4
    4WP Factory Front Bumper w/Warn VR EVO 10-S Winch, AuxBeam 8-Switch Controller, Redarc Trailer Brake Controller, ARE CX-Evolve Cap, Bedrug Liner, Ditch Pod Lights, Aftermarket LED (OEM) Bed Lights, Console Vault
    I know this is a problem with 1st gens...something about current sensing to feed enough power to the light. I was going to look into possibly putting a resistor up there of some sort, but ive just been too lazy to get a few different rating resistors...but once I find the right one, I'll do a write up.
    If you get to it before I do, let me know! I'm pretty sure that's the problem. The stock bulbs need more current than the led strips.
  7. May 1, 2011 at 6:01 PM
    moto932
    Eric
    Dayton, Ohio
    04 TRD Off Road
    thanks for the info but im clueless when it come to electrical work. why would it work for 7 years then all of the sudden stop working?
  8. May 1, 2011 at 7:31 PM
    MHS2846bg8
    Nate
    ah...I didn't see that the filament wasn't broken... The bulb may have worn out or there may be a short somewhere...but from what I'm assuming, the problem with the dome light only coming on when map lights are turned on is because the dome isn't pulling enough current to switch something on.
  9. Jun 2, 2011 at 7:05 PM
    moto932
    Eric
    Dayton, Ohio
    04 TRD Off Road
    bump, still haven't figured this out :(
    what would cause this and how could it be fixed?
  10. Jun 3, 2011 at 8:05 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    ^ This.
  11. Jun 3, 2011 at 8:10 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You could verify that the old bulb works by wrapping a bare wire around the base of it, touching the end to the positive terminal on your battery and the wire against the negative.
  12. Jun 3, 2011 at 9:57 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Your dome light is missing its ground, or is shorted to the map light.
  13. Jun 3, 2011 at 10:10 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's not a ground on 1st Gens when the key is turned off it's dims the dome light so if you install a LED it will not turn on unless you turn the key on. if you pulled that LED out right now and installed a filament bulb it would work just fine.
    And yes the map and dome lights are on the same 12v source and that is why if you turn on the map lights your LED will turn on. Try and installing a LED in the map lights as well they will not turn on unless the key is on.
    There is a way to fix it.
    This is what I'm going to do is wire a #74 bulb inline with the dome and paint over it so no light is let out and the right amount of current is drawn and the LED's will light up. Ive seen it before and it works great. The only other way is rewire the dome light to a straight 12v source and they will work fine.
  14. Oct 5, 2011 at 6:53 PM
    moto932
    Eric
    Dayton, Ohio
    04 TRD Off Road
    finally got my dome light working again. not real sure what i did but it works. i took the map light completely apart and unplugged it. blew the fuse in the process by touching my screwdriver to a couple thing i wasnt supposed to. re-installed the map lights, threw in a new fuse and BAM, it works. so i guess it must have been a bad ground? if thats the case, wonder why it didnt start working the frist time i disassembled it? oh it works now. thanks for everyone input, it is appreciated :thumbsup:
  15. Nov 10, 2011 at 8:41 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
