Dome light troubles
Discussion in 'Lighting' started by Main'a, Feb 15, 2014.
  1. Feb 15, 2014 at 1:20 PM
    Main'a
    Main'a [OP] New Member
    Maine
    97 tacoma 2.7lt 4cyl. 5spd.
    Custom made deer atler for 4x4 knob
    Hi there, got a 97 tacoma with a dome light that has an issue. light will come on in the on position and door position with the door closed and open. When i close the door, with the light in the door position, the light stays on. Open the door and i push the door button the door ajar alarm/ beep tone goes away. Not sure where to go from here.
  2. Feb 15, 2014 at 4:09 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Sounds like u need a new pin/plunger switch.
    This will also effect any alarm as well.
  3. Feb 16, 2014 at 10:32 AM
    Main'a
    Maine
    Thats what got me though is that i can open the driver side door and the door open tone with sound when the key is in the ignition but no light and the passenger side, when the door is open will do nothing. Could it be the passenger side door switch effecting the whole system?
  4. Feb 16, 2014 at 6:18 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I'm not sure if the switches are on independent circuits or not.
    But the 1 switch may be throwing the whole thing outta whack.
    Just look what happens when people use a single filament bulb in a brake light on some vehicles..... Sometimes it causes weird stuff like the dash lights to blink, or brighten and dim, or other odd things.
    Should be a cheap test tho.... I can't see the switch costing much.
  5. Feb 16, 2014 at 7:47 PM
    joes06tacoma
    Joe
    Central Coast, CA
    On my 2004 I had, there was a body control module built into the fuse box that controlled auto-off headlights, and other things probably. Since something happens when the door is opened on the driver's side, that switch is good. I would think it's in the fuse box/control module, but need a schematic.
  6. Feb 23, 2014 at 7:54 AM
    Main'a
    Maine
    It was indeed the passenger side door jam switch. What was happening was the door was not closing enough to turn the light off, in fact it wasn't even touching it at all. witched messed with my trouble shooting because I could just tap it with my finger and the light would go out. For a fix I just popped the rubber cover off and added a small metal nut to the inside of the cover, giving it length for the door to hit it.
