Dome light won't work, checked everything
Discussion in '1st Gen. Tacomas (1995-2004)' started by Christt, Jan 25, 2015.
  1. Jan 25, 2015 at 6:08 PM
    Christt
    Christt [OP] New Member
    California
    Hi, I have a 1998 toyota tacoma 2.4 regular cab
    no power windows or power door locks.
    My dome light won't work. I already checked the fuses.
    Gauge and dome fuse are ok.
    Replaced bulb and still didn't work. Can anybody help me out. Thanks
  2. Jan 25, 2015 at 6:20 PM
    dirtkarter
    dirtkarter Well-Known Member
    Jonathan
    Alabama
    sr5
    Lift,wheels,tires
    are the jamb switches working could be filled with dirt not allowing it to release
  3. Jan 25, 2015 at 9:07 PM
    Christt
    California
    Yes they do work, they move freely. I don't know what else to check
  4. Jan 26, 2015 at 8:43 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You need to trace the problem back from the dome-light switch itself.
    Check whether or not there is power at the switch. The all black wire should be hot all the time.
    Also, check if there is power at the dome fuse. One side should be hot all the time.
    If you don't have a multi-meter for this, get one. If you don't have one, or know how to use one, then ask someone to help you.
