Dome Light
Discussion in 'New Members' started by granny who, Feb 12, 2023.
  1. Feb 12, 2023 at 3:56 PM
    granny who
    granny who [OP] New Member
    Toyota
    I was trying to replace the dome light bulb using a needle nose and saw a spark . I think I may have caused it to short out. Now my anti-theft device won't work and I can't lock the doors manually. Where should I start?
    buckhuntin-tacoma likes this.
  2. Feb 12, 2023 at 3:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Maybe it blew a fuse?
    Is the light not working?
    What year is your truck?
  3. Feb 12, 2023 at 4:03 PM
    granny who
    Toyota
    I gave up on the bulb after the spark. Too dam hard to get it in the right position. 2001Tacoma. I've had issues with it since I bought it.
    Just wondering if the spark is what caused the issue with the anti- theft and door locks
  4. Feb 12, 2023 at 4:48 PM
    TnShooter
    Deogee
    STOCK
    Are you saying the electric door locks don’t work?
    Or that you can’t lock the doors with the key?
    The Dome light (if set to Door), and the door locks are controlled by the Body ECU.
    It’s possible you have a bad door switch?
    Some vehicles won’t let you lock the door if one of the doors is open.
    My diagrams don’t show a “door” light on the dash. So testing them isn’t going to be easy.
    Unless, you install a dome bulb. If the dome light comes on/goes out when you open and close a door, you know that door detection switch works…..
  5. Feb 12, 2023 at 4:59 PM
    granny who
    Toyota
    Can't lock doors with the key fob or the keys. I'll try inserting the bulb first then check the fuse. If all else fails maybe go to the dealer. Thanks for your help!
  6. Feb 12, 2023 at 5:15 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    TnShooter likes this.
