Dome light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rougarou680, Aug 20, 2023.
  1. Aug 20, 2023 at 1:17 PM
    Rougarou680
    Rougarou680 [OP] Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    I replaced the dome light bulb with an LED in wife’s 2013 Tacoma. It didn’t work at first, so when I went to pull it out, it began working. She told me since I messed with it her radio & clock reset. Any idea why? I also pulled the dome fuse under hood to check it & put it back in.
  2. Aug 20, 2023 at 1:41 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    When you pulled the fuse it cut power. Reset and carry on
    Geeves77 likes this.
  3. Aug 21, 2023 at 10:35 AM
    Rougarou680
    Lousyana
    She reset it. I was just confused because the fuse was labeled Dome, & there’s a different fuse labeled Radio.
