Dome lights and Clock malfuction
Discussion in '2nd Gen. Tacomas (2005-2015)' started by apotter, Mar 12, 2011.
  1. Mar 12, 2011 at 10:56 PM
    apotter
    apotter [OP] Well-Known Member
    Southern Maine
    2023 Tacoma
    Had something really strange happen tonight with the dome lights, map lights and clock. Opened the door and the dome light didn't come on; Played with the switch with no results. Tried the map lights, and nothing. Then realized the clock was lit, but not displaying the time. thought it was strange but continued on my way. But wait..it gets even more strange. Used my high beams and the dome light came on! Back to low beams and the light went out. How F'd is this? Has anyone else experienced this?
    Everything seems to be working again once I stopped the truck and opened the door, but Toyota had better be ready to do some serious investigation on a babied truck with 20K miles if it happens again.
  2. Mar 12, 2011 at 11:58 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    If under warranty and as reproducible as you say, take it into toyota ASAP before the problem changes or fixes itself.
    Nothing to lose but time, and if wires are shorting etc a lot to gain.
  3. Apr 10, 2011 at 5:31 PM
    apotter
    Southern Maine
    2023 Tacoma
    this strange occurance happened again the other night, but this time nothing back back. Checked the fuse and found it had melted..didn't burn out but deformed. Popped in a 2.5 amp (system calls for a 5.0 amp) fuse in, put the old bulbs back and everything is working fine. Guess LED's are always better.
  4. Apr 10, 2011 at 6:52 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Everything is not fine. Fuses blow because something is wrong. You have a short to power(one circuit is shorted to another). Take it in, or hunt for the short, or do nothing and have it bite you in the ass later.
    kimo likes this.
  5. Apr 10, 2011 at 7:29 PM
    apotter
    Southern Maine
    2023 Tacoma
    Probably should have prefaced this with the fact that I installed LED's in the dome light and map light area, and a few days later started having the fuse melting problem. Putting the stock bulbs back in remidied the problem. Meant to say LED's are not always better in the last post. I fear putting LED bulbs in as a replacement after this episode. If this happens again with the stock bulbs, there is no question as to whether or not it should be making a trip to the dealer.
  6. Apr 11, 2011 at 2:29 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I see... you created the short to power;)
  7. Apr 11, 2011 at 6:32 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Where did you buy the LED's from? If it was a prewired replacement I would call them up and talk to them about the problem.
  8. Apr 11, 2011 at 6:42 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Perhaps they were connected across two power leads, since two circuits were interacting with each other. Hook up the lights directly to the battery, if they work properly, you know where they problem lies.
    I have been guilty of miswiring other accessories. Grounds missing, wrong lead hooked up to a relay, just go through your work and make sure.
  9. Apr 11, 2011 at 10:04 AM
    apotter
    Southern Maine
    2023 Tacoma
    The replacment LED's were straight from Hong Kong, and considering the bulbs were only about 50 cents a piece, they will likely make their way to the trash, and no sleep will be lost.
    It's been mentioned I should check the wiring I've done...but I think there is some confusion; All I did was take out the factory bulbs, plug in the replacment LED's, then encountered problems. Once the fuse was replaced, and the factory bulbs were restored to their place, all has been well since. No wires were moved, shifted, spliced or touched in anyway, and that's they way I would really like for it to remain if possible.
    Must admit, if I had done any wiring and come up against the blowing fuse issue, I probably wouldn't let anyone know on TW...mostly likely there would be hours of retracing with visual inspection, and then the multimeter would be brought into action; years of working on tractor trail truck wiring has taught me a frew tricks: A-Never splice B-always solder connection C-always use factory (or gates) plugs D-Use wire ties, and E-heatshrink and dielectric grease are your best friends :) Haven't had any issues using these tricks in New England where ice hangs on wires, and salt attacks points of weakness.
    Hopefully this didn't come across as pompous..I do appreciate the suggestions!
  10. Apr 11, 2011 at 10:07 AM
    apotter
    Southern Maine
    2023 Tacoma
    Also, if anyone has a chance to use amphenol connectors, I highly recommend them for severe weather use...These things worked excellent for my teams competition snowmobile.
  11. Apr 11, 2011 at 1:37 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    OP, I wouldn't test the LED lights. It looks like the one that was in the dome is shorting. A short directly across the battery could hurt you. You are lucky that you didn't burn out the Body ECU while the LED was installed.
  12. Apr 11, 2011 at 2:19 PM
    apotter
    Southern Maine
    2023 Tacoma
    Yikes..burn out the ECU by installing a direct replacment LED light seems a little extreme; One would hope Toyota wouldn't manufacturer a vehicle that burnt out the ECU when bulb had a short...quite positive the correct size fuses will keep anything major protected from boneheads like me who decide to replace electrical wear items with aftermarket pieces.
  13. Apr 10, 2018 at 7:38 PM
    Gray Bandit
    Gray Bandit New Member
    Roland
    Titusville FL USA
    2015 Toyota Tacoma TRD Sport with Bull Bar and LED Lights
    Bull Bar, LED Lights in front, Bug Shield, Black Tool Box
    I know this thread has been some time but I have had the same exact thing happen with my 2015 Tacoma. I installed the led lights and they shorted out. Does anyone know which fuse it is. I have to find it but havent had time to look. Thanks
  14. Apr 10, 2018 at 8:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    LEDs suck and cause more problems than they are worth. I'd be willing to bet you will not have more issues unless you install LEDs back.
    Plain Jane Taco likes this.
  15. Apr 10, 2018 at 8:32 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    DOME Under the hood.
  16. Apr 11, 2018 at 12:57 AM
    Gray Bandit
    Roland
    Titusville FL USA
    Awesome! I agree the LED's are really a pain in the Ass unless the vehicle already has them. Thanks for the info.... I will check it out later today!
