Dome Lights stays on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by get-er-dirty, Feb 18, 2019.
  1. Feb 18, 2019 at 9:13 AM
    get-er-dirty
    get-er-dirty [OP] Well-Known Member
    J
    Black 17 SR5
    Question:
    Changed out my Dome and Map to LEDs.
    ISSUE:
    Started last week my lights will no longer turn off automatically, when I close my door or start my truck.
    When I have the light switch switched to (Middle position) lights just stay on and will not fade off when door are closed or when I start my truck.
    The dash shows the picture when any of the doors are open, so that still works. When I move the switch to the off position, I can still manually push the map turn on the lights and move the dome lights to the on position. Lights will not turn off automatically.
    I changed the fuse, checked and open all the door contacts.
    Hopefully someone has some ideas I can try.
    Thanks
  2. Feb 18, 2019 at 9:15 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    3rd gens lights turn on as you approach the vehicle. Do you think that could be what's going on? I thought for sure I left my lights on until I realized it.
    Just realized you said they're on when the vehicle is running. That sounds like a problem. Good luck, I hope you get a good response.
  3. Feb 18, 2019 at 9:34 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Make sure the dome light switch is on auto. You might have accidentally switched it to off position while changing the bulb
  4. Feb 18, 2019 at 9:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Put the OE bulbs back in and see if that corrects the problem.
    Big tall dave, over60 and shakerhood like this.
  5. Feb 21, 2019 at 6:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    Well, did you solve the problem?
    Learning results is good for everyone...........
  6. Feb 21, 2019 at 7:09 AM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Just to clarify... Only those equipped autos with the proximity key have this feature. Manual trucks must hit the unlock button on key before lights come on. Just wanted to mention that. I wish they came on like that but they don’t.
  7. Feb 21, 2019 at 7:50 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    I would try putting stock bulbs back and re test
  8. Feb 21, 2019 at 7:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    :gossip: see post 4
  9. Feb 21, 2019 at 8:02 AM
    get-er-dirty
    J
    Black 17 SR5
    I put the original lights back and still have the same issue. I will do more internet searching. I can't be the only Taco owner with this problem :(
  10. Feb 21, 2019 at 8:04 AM
    Siblue
    So Cal
    25 Tundra TRD pro
    The LEDs possibly caused a feedback to the control unit. I would have dealer warranty it, which stock bulbs installed. Yes, you're not the only member with this issue.
  11. Feb 21, 2019 at 8:07 AM
    get-er-dirty
    J
    Black 17 SR5
    Exactly what I was thinking. I have a schedule maintenance coming up, I will have them check it out.
  12. Feb 21, 2019 at 8:27 AM
    Siblue
    So Cal
    25 Tundra TRD pro
  13. Feb 21, 2019 at 9:04 AM
    get-er-dirty
    J
    Black 17 SR5
