Dome lights won't turn off!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jadoiron, Nov 22, 2015.
  1. Nov 24, 2015 at 7:54 AM
    theBoss
    theBoss Member
    16' Tacoma TRD Sport
    Im having the same issue. I put led's in the map lights and dome light. Worked fine for two weeks. A few days ago the fuse blew. Replaced it and the interior lights stay on while in door position. I've already tried all things mentioned in the posts above. My baby will go to the dealership in a few days for this issue. I'll keep you guys posted on what they find. Oh and yes I've put the stock halogens back in.
  2. Nov 24, 2015 at 8:17 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Not trying to be a dick here, but are you going to tell them the truth about what happened?
    Nessmuk and busticator like this.
  3. Nov 24, 2015 at 8:31 AM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    guess theres a reason why we have LED cargo lights and halogens on the rest...
  4. Nov 24, 2015 at 9:40 AM
    pngo121
    Phi
    Pittsburg, CA
    was going to get all my interior LEDs soon too. glad i ran into this thread.
    sadmrhappy and scottalot[QUOTED] like this.
  5. Nov 24, 2015 at 9:46 AM
    pngo121
    Phi
    Pittsburg, CA
    I had some problems when trying to install LED brake light bulbs on my 2012 Tundra. they keep toasting my fuse and causing none of my other exterior lights to work so I gave up and put the halogens back in.
  6. Nov 24, 2015 at 9:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    LEDs are over rated.
    Kilokato, scottalot and CusterFan like this.
  7. Nov 24, 2015 at 9:53 AM
    pngo121
    Phi
    Pittsburg, CA
    looks much cleaner with LEDs but everyone has their own opinion.
  8. Nov 24, 2015 at 9:53 AM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    being that a LED takes much less resistance than halogen, what happens if you had a resistor in parallel with the LED?
  9. Nov 24, 2015 at 9:54 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I'm afraid to jump start someone let alone change out the bulbs for LED's.
    scottalot[QUOTED] likes this.
  10. Nov 24, 2015 at 9:55 AM
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    Had a tundra with a shorted dome light. Fried the circuit in the body control module.
  11. Nov 24, 2015 at 9:55 AM
    mbarbay
    Baton Rouge, LA
    another thing, is that the switch itself could have blown and fused the door and on together
    scottalot likes this.
  12. Nov 24, 2015 at 3:24 PM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    since no one asked, where did OP get the lights from? ebay? Amazon? or from vleds?
    have not had 1 issue with my vleds, even moving them from the 2012 Tacoma to the 2016.
    chemjab likes this.
  13. Nov 24, 2015 at 3:49 PM
    Kentuckytaco2006
    Kentuckytaco2006 Well-Known Member
    Mark
    2006 Red Prerunner Doublecab
    I received my LED bulbs last week from Super Brite LED'S like most on here seemed to recommend....but didn't install them yet...after reading this thread I contacted the vendor and requested to return them....I'm not going to have electrical problems over a bulb that is 1/2 inch long....once those things start happening, its like gremlins, they just keep popping up everywhere! Wow, am I glad I didn't install them...
    Riding Dirty likes this.
  14. Nov 24, 2015 at 4:10 PM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Have you guys checked the relay and run any tests from there?
  15. Nov 24, 2015 at 9:13 PM
    #35
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    Ok any technical ghurus here? Why would LEDs make a difference? Perhaps some contacts were shorted out that blew the fuse. THAT is what the fuse is for! If some control module is damaged then obviously the fuse did NOT work.
    Please keep us posted to what you find. I have zero problems with mine from superbritelights....and I don't want anything to happen to my system.
    :annoyed:
  16. Nov 24, 2015 at 9:23 PM
    #36
    victor in the desert
    victor in the desert Well-Known Member
    victor
    2011 tacoma prerunner
    I replaced the light too and I have no problem but don't know what to tell you . Sorry just maybe play with the fuses. Good luck but while you are replacing dome light you should also replace map lights too just be careful not to cut yourself with the shape metal edge.
  17. Nov 25, 2015 at 1:10 AM
    #37
    AndyNguyen
    AndyNguyen Well-Known Member
    Can you go to the head unit: setting-vehicle to reset the interior lights?
    chemjab likes this.
  18. Nov 25, 2015 at 3:32 AM
    #38
    thepinktaco
    Cody
    Orange, MA
    A fuse will protect the circuit from overloading when shorting power to ground. It will not protect shorting power to a computer controlled circuit. If you short power to a computer controlled wire you can burn the contacts out.
  19. Nov 25, 2015 at 5:32 AM
    #39
    ElderP
    ElderP Well-Known Member
    West Virginia
    15 Access 4x4 V6 SR5
    Installed Cooper At/3's (265/70R16) and ProComp 7089 Rims. Tinted front windows. Did the Fog Light Anytime mod. Did the tailgate mod. Added running boards. Adding sound Deadening from RAAMaudio. Replacing stock speakers with Polk Audio DB6501's.
    Then every light would stay on :)
  20. Nov 25, 2015 at 9:25 AM
    #40
    MN5oh
    MN5oh Active Member
    2016 Black TRD Sport DBL Long bed
    Where did you get your lights from?
