Dome / Map light Mod Issues?
Discussion in 'Lighting' started by Dane-Taco, Nov 11, 2009.
  1. Nov 11, 2009 at 7:34 PM
    Dane-Taco
    Dane-Taco [OP] Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    Good evening TW,
    Earlier today I started the map light mod that includes the diode. Now, neither the map lights nor the dome light work.
    First, what size diode is used? I am using a 3A 50 PIV diode. This has 230K ohms of resistance, that seems high? All instrument lights work but the clock doesn't work? (the clock's back light works, just no numbers) I checked the 7.5A dome light fuse, that is good. Are the two wires i flipped on the connector causing this issue? Does the mod that only calls for a ground wire from the dome require this flip? Any info would greatly appreciated!!
  2. Nov 12, 2009 at 4:28 PM
    Dane-Taco
    Justus
    Wasilla, AK
  3. Nov 12, 2009 at 4:31 PM
    98tacoma27
    Ben
    Not Beech Creek
    do you have the diode backwards?
    link to the mod?
  4. Nov 12, 2009 at 4:50 PM
    Dane-Taco
    Justus
    Wasilla, AK
    I have the diode's negative end soldered to the map light board and the positive end is connected to the dome light ground.
  5. Nov 12, 2009 at 4:53 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Click my link in my sig for "installing compass" thing.. I have a picture that shows the correct way to soder it.. i'd link you to it manually... but i'm lazy
  6. Nov 12, 2009 at 6:57 PM
    Dane-Taco
    Justus
    Wasilla, AK
    Yup, had the diode backwards and blew a fuse. Works great now! Thanks bro!!
  7. Nov 12, 2009 at 7:32 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    ah good job! now you'll never forget how a diode works ;)
  8. Nov 8, 2010 at 2:01 PM
    Taco Time 208
    Taco Time 208 Member
    Idaho
    08 access cab,V6,4x4,TRD
    bone stock
    What fuse did it blow?
