Dome, Maps and Clock not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tosscobobble, Nov 17, 2022.
  1. Nov 17, 2022 at 10:24 AM
    tosscobobble
    tosscobobble [OP] Member
    Roger
    '08 Tacoma 4-cl
    2008 Tacoma Access cab, Base with Convenience Package, 4cyl
    Dome light went out a few weeks ago. Finally get a new bulb, decided on an LED hoping for brighter. Nothing happened. Jiggled it around, got a brief flash from the bulb, then nothing.
    Next day, mess with bulb again without luck.
    Third day, map lights not working and clock was reset. Try map light and lose clock.
    I've seen it could just be a fuse, but an odd progression of fails it seems.
    I didn't see anything on the dome LED that indicated a direction for installation (and neither did any how-to videos)
    I'll check the fuse today. How likely is it that it could be a wiring problem. Note: I've never had any issue with electric anything until now.
    Ideas/Suggestions?
  2. Nov 17, 2022 at 10:43 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check your Dome Fuse 7.5A in the underhood fuse box, you may have popped it if you put the LED in backwards.
  3. Nov 17, 2022 at 11:23 AM
    tosscobobble
    Roger
    '08 Tacoma 4-cl
    The fuse is dead. Popped in a spare 10 to see what happens (Only for a quick look)... Clock and maps are good, but the dome is completely dead.
    Going to pick up new fuses and a standard bulb and see how it goes
    If LEDs are supposed to go in a certain way, you'd think there would be instructions or something for it:facepalm:
  4. Nov 17, 2022 at 11:56 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Your dome also grounds to the body through the metal clips that hold it into the headliner. I have had a similar issue and bending those clips out to make better contact resolved the issue. A touch of axle grease wouldn't hurt either(between the clips and the roof) to promote conductivity.
  5. Nov 17, 2022 at 12:23 PM
    tosscobobble
    Roger
    '08 Tacoma 4-cl
    Interesting... I guess this might be a bit more involved than I thought.
  6. Nov 18, 2022 at 2:27 PM
    caribe makaira
    Caribbean, Puerto Rico
    :rofl::rofl::rofl:
  7. Nov 18, 2022 at 2:29 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    helpful.
  8. Nov 18, 2022 at 2:31 PM
    caribe makaira
    Yes indeed, better than stupid advice.
  9. Nov 18, 2022 at 2:36 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Cool you could just say that but I guess being a dick is more your style. Nice work.
  10. Nov 18, 2022 at 2:39 PM
    tosscobobble
    Roger
    '08 Tacoma 4-cl
    I am so much more enlightened by your contribution....:duh:
    reallifedog likes this.
  11. Nov 18, 2022 at 2:40 PM
    caribe makaira
    Glad you see your reflection.
  12. Nov 18, 2022 at 2:42 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    yes indeed, and thanks for the stupid response.
  13. Nov 18, 2022 at 2:43 PM
    tosscobobble
    Roger
    '08 Tacoma 4-cl
    Anyway
    A new fuse and regular bulb did the trick, thankfully.
    The packaging for the LED bulb did have a note about ensuring proper alignment, but it was under the theft prevention sticker. And there wasn't anything on the bulb or anything to indicate a direction. Oh well.
    Thank you all (not all) your assistance
    Dm93 likes this.
  14. Nov 18, 2022 at 2:45 PM
    caribe makaira
    Remember to use the axle grease...:rofl:
    AllTacosFloat likes this.
  15. Nov 18, 2022 at 2:47 PM
    tosscobobble
    Roger
    '08 Tacoma 4-cl
    Hey, I know you think you are being clever, but you aren't. In fact, I'm embarrassed for you.
    Please refrain from 'contributing' on any of my posts in the future.
  16. Nov 18, 2022 at 2:47 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Meanwhile the guy you're slamming is probably the most electronics blah blah qualified in here. If I had trouble he would be on the short list of who to listen to.
    Remember it's internet no need to get upset
  17. Nov 18, 2022 at 2:49 PM
    AllTacosFloat
    Boston ish
    Is red n tacky a good substitute?
  18. Nov 18, 2022 at 2:51 PM
    tosscobobble
    Roger
    '08 Tacoma 4-cl
    In all fairness, I'd rather keep searching for help than to deal with an ass. Qualified or not, there's no need to be a dick
  19. Nov 18, 2022 at 2:56 PM
    AllTacosFloat
    Boston ish
    I don't think he was being a dick, I think he was laughing at saying that it grounds through the metal clips. I believe there is just one ground. Might be mistaken. Also laughable to use axle Grease instead of Dielectric grease especially in your interior.
    Look up the members helping you. 2 of them have a record of being extremely helpful to others. Then you have a guy that wants you to put axle Grease in your headliner
  20. Nov 18, 2022 at 3:03 PM
    tosscobobble
    Roger
    '08 Tacoma 4-cl
    Yes, the same 'qualified' person you noted...
    He could easily had said that's not true, or even flat out stated the other person was wrong. Only emojis does nothing to aid anyone
    That being said, how do I shut down a thread?
