Donahue racing suspension questions
Discussion in 'Suspension' started by austinrauh, Mar 5, 2017.
  1. Mar 9, 2017 at 9:10 AM
    #41
    austinrauh
    austinrauh [OP] Well-Known Member
    Nevada
    05 AC OR
    Ok cool thank you!
    Yeah I might as well install it all at once, I have a plan in my head.
    Will fox coils fit my suspension?
  2. Mar 9, 2017 at 9:49 AM
    #42
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
  3. Mar 9, 2017 at 10:08 AM
    #43
    Firebird
    Firebird Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    Exactly what @TMFF said. ID is the inner diameter of the coil.
    2.5" coilovers (2.5" being the outer diameter of the shock section) like yours use the 3" ID springs, regardless of who makes it (be it King, Eibach, etc).
  4. Mar 9, 2017 at 10:13 AM
    #44
    austinrauh
    Nevada
    05 AC OR
    @Firebird @TMFF
    Ok awesome that clarifies my question, I found a good deal on a fox spring but it was 13" tall so that won't work.
    Firebird likes this.
  5. Mar 9, 2017 at 10:20 AM
    #45
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    No plate bumper & no winch? If so, 600# springs @ 14" tall w/ 3" ID is what you're looking for.
  6. Mar 9, 2017 at 10:23 AM
    #46
    austinrauh
    Nevada
    05 AC OR
    Perfect, would upgrading pump stops be a good idea while I have everything torn apart? Any suggestions?
    Then I was reasearching last night that you just adjust from 2" to however much lift you want by preloading, so this makes leveling both sides easy correct?
    I found a good thread on it, where people with icons were saying how much thread space they had with what lift they got
    Also any reccomandatijns in good extended brake lines? Could I instal myself? (I have bleed brakes before)
    Firebird[QUOTED] likes this.
  7. Mar 9, 2017 at 10:58 AM
    #47
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    What brand of spring is this and what's the static ride height with the show amount of preload you're running?
    austinrauh[OP] likes this.
  8. Mar 9, 2017 at 11:21 AM
    #48
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    For the brake lines I'll point you here: https://www.tacomaworld.com/threads/extended-brake-lines.272063/
    As for installing them yourself, I wouldn't say it's a hard job but it's not one I was willing to do myself (I don't mess with my brakes).
    Leveling both sides in the front is done with a spanner wrench that fits your coilovers. I have found that a Fox 2.5" c/o spanner won't fit King 2.5" c/os and vice versa so make sure yours will work before ordering.
    I'd recommend you do rear bump stops personally. Look up a U-bolt flip and what bumps to use from there. You want your bumps to stop your axle just before your shocks run out of compression travel.
  9. Mar 9, 2017 at 11:46 AM
    #49
    austinrauh
    Nevada
    05 AC OR
    Ok cool thanks for the info!
    A. Might as well do all that kind of stuff while I'm tearing into everything
    B. I want it done right not the way the previous owner had it, I mean it rides ok right now but I bet it will ride way better after all this
  10. Mar 9, 2017 at 12:19 PM
    #50
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    You're going to be happy once it's done right :thumbsup:
    IG follow coming your way btw
  11. Mar 9, 2017 at 12:43 PM
    #51
    austinrauh
    Nevada
    05 AC OR
    yeah I think so! I think i'll put new bushings in the Lower control arms too, or is that not a huge deal?
    thanks man!:proposetoast:
  12. Mar 9, 2017 at 12:54 PM
    #52
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    An LCA bushing job is literally the devil's mistress. You start to fuck with it, then hell opens up with all its might.
  13. Mar 9, 2017 at 12:57 PM
    #53
    austinrauh
    Nevada
    05 AC OR
    ok then ill pass, I just remember a thread on here about a common thing is the LCA bushing? (whats the part that connects to the hub assembly) will go out over time? should I just do that? or if everything feels dandy just not do it. with going 3" in the front do I need to extend brake lines/ abs sensor up there? do anything with cv's? mess with steering/ sway bar stuff? or will a 2.5" just save me a bunch of head aches?
  14. Mar 9, 2017 at 1:13 PM
    #54
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I used to roam on TTORA before when DR was still around before going on a hiatus for a little bit. I knew that Icon had absorbed DR, but was sad to find out that they got formed from a very shady deal. I feel like I keep finding out more and more interesting facts about them. As far as service, I would love to send my stuff locally over across the US just for the manufacturer to do it for me.
    Coot
  15. Mar 9, 2017 at 1:18 PM
    #55
    austinrauh
    Nevada
    05 AC OR
    can any suspension shop rebuild?
  16. Mar 9, 2017 at 1:22 PM
    #56
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Well considering you are in Nevada and there is a decent race scene out there, I would think shops could. I would call around and see, the ones that will should be pretty familiar with tacoma coilovers to begin with if they are. These coilovers are "rebuildable" in that anyone who can get the parts and has the know how should be able to service them. Your DR coils might be an exception, but most parts are easy to get.
    Coot
  17. Mar 9, 2017 at 1:23 PM
    #57
    austinrauh
    Nevada
    05 AC OR
    copy that, i'll post in my local thread when the time comes
    Coot83[QUOTED] likes this.
  18. Mar 9, 2017 at 1:27 PM
    #58
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    Well your alignment cams will tend to seize to the LCA bushing. The alignment cams have sleeves that fit into another metal sleeve in the LCA bushing. That rusts and prevents proper alignment and removal. That's a pain to fix. Going to Poly is a flaming whore as well. Toyota's LCA design isn't the easiest to work with.
    Shouldn't need to extend the front brake lines, but someone can correct me there. CVs will be fine, they'll start clicking if they're going bad. There is an issue with the needle bearing on the driver's side. Lots on here about that. Spindles can bend, just something to keep in mind. Don't worry about steering too much, but make sure you have that swaybar relocation bracket.
  19. Mar 9, 2017 at 1:37 PM
    #59
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
  20. Mar 9, 2017 at 1:43 PM
    #60
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I recommend timbern bumpstops up front work well and take an abuse. ive had mine for 3 years up front and I'm also running them in the rear.
