Donahue racing suspension questions
Discussion in 'Suspension' started by austinrauh, Mar 5, 2017.
  1. Mar 9, 2017 at 1:57 PM
    #61
    austinrauh
    austinrauh [OP] Well-Known Member
    Nevada
    05 AC OR
    awesome,ill look into them
    edit looked them up, this would give me that u bolt flip at the same time too
  2. Mar 9, 2017 at 2:01 PM
    #62
    austinrauh
    Nevada
    05 AC OR
    Firebird[QUOTED] likes this.
  3. Mar 9, 2017 at 4:02 PM
    #63
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    That is correct and also rear they make a kit where you can use stock ubolt style.
  4. Mar 9, 2017 at 4:04 PM
    #64
    austinrauh
    Nevada
    05 AC OR
    I'm planning on getting a different leaf pack, will this generaly work with most of them?
  5. Mar 9, 2017 at 4:13 PM
    #65
    BAMFTACO
    Juan
    Kings bruh
  6. Mar 9, 2017 at 8:53 PM
    #66
    Justinlhc
    Justinlhc Not looking for a relationship
    14" King. I believe it's around a 3" lift.
    23.5" from center of hub to fender.
    maxtherat[QUOTED] and Firebird like this.
  7. Mar 10, 2017 at 6:11 PM
    #67
    austinrauh
    Nevada
    05 AC OR
    just to update the thread I measured some stuff, hub to fender: 23 1/2" (both sides), open thread space: 2 1/4" driver side, 2 3/8" passenger, spring vin number: DR 158504 B, shock vin: 009560 (this # was on the top head of it facing the front of the car, on the side it said "DR" then on the back of the shock it said "2.5"
    I read somewhere that the spring for these is 13" #650 but couldn't find if the inside diameter is 3" or 2.5" i've herd both or are they the same thing? I just want to avoid ordering the wrong part, and would it be smart to go down to #600 or will the 14" help with that.
    Also good news, found out I already have the sway bar relocation:thumbsup:
    decided to hold off on new bump stops..
    so far my list is:
    any suggestions on the list/ places to get them cheaper or know of any 2nd hand sellers? thanks! bout to say bye to some cheese haha :wave:
  8. Mar 10, 2017 at 11:36 PM
    #68
    austinrauh
    Nevada
    05 AC OR
    @HeadStrong Off-Road ive heard a lot of good things about your knowledge of suspension, could you have some possible info that I'm not covering? If not no worries just trying to hit all my bases!
    HeadStrong Off-Road likes this.
  9. Mar 15, 2017 at 1:37 AM
    #69
    G.T.
    G.T.
    CONUS
    I just looked at your pictures and your rears look like the first version of remote reservoir shocks that they made which used weird internals that I doubt most shops have or can source. I'm sure someone out there can handle them but I'd make certain that they understand what you are bringing to them before they start tearing stuff apart.
    You've been given some good suggestions for rebuild shops but I'd also suggest Matt @M C M in Nevada, or Micah @Downsouth Motorsports in California. Both very sharp people who are well known to be stand up guys that can help you out with sales and service.
    Coot83 likes this.
  10. Mar 15, 2017 at 12:33 PM
    #70
    austinrauh
    Nevada
    05 AC OR
    Awesome thank you for the advice!
    I reasearched as much as I possibly could on the rear shock from other forums, but most said that they were designed for 2 to 4 or 5" lifts if I remember. I'm purchasing a used all pro leaf pack that was said to give me 3" lift, I should be ok right?
  11. Mar 15, 2017 at 2:52 PM
    #71
    G.T.
    G.T.
    CONUS
    Most likely that combination wouldn't cause any problems but before you spend the money I'd measure the static, compressed, and extended while installed and then pull at least one of the rears off and measure static, compressed, and extended in case you do have a longer rear shock than you think.
    Hope that you find success in your upgrades and you get to continue to use what you have.
  12. Mar 15, 2017 at 7:43 PM
    #72
    austinrauh
    Nevada
    05 AC OR
    I'm getting a pretty good deals on all pro this weekend, it is there standard leaf pack, but thanks for the kind words!
    I'm stoked I have good suspension I just want to make sure it's 100% solid for the long run you know? I like stuff done right
    Also is there a good thread on installing extended brake lines?
  13. Mar 15, 2017 at 9:38 PM
    #73
    G.T.
    G.T.
    CONUS
    Quite certain there is. One fella even has a deal where he has custom length lines made to order in the group buy section. I bought a set from him and have had no issues.
