Done
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CO_0321er, May 30, 2017.
  1. May 30, 2017 at 8:40 AM
    CO_0321er
    CO_0321er [OP] Well-Known Member
    Done
  2. May 30, 2017 at 8:45 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    LCA bushings?
    EDIT: Just seeing you mentioned that.
    Could also be the brake pad shifting issue but that's not what i'd consider loud like two metal bricks clapping.
  3. May 31, 2017 at 6:55 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Sway bar hitting coil?
    GDT likes this.
  4. May 31, 2017 at 7:00 AM
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    I've had two 'bangs' in the past that are similar to what you describe. One was resolved by tightening LCA bolts as they had come loose while off road. The other was resolved by applying a liberal amount of grease to the surface of the front steering stops.
    Good luck tracking this down.
  5. May 31, 2017 at 7:07 AM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    This was my guess too. My driver side away bar touches my coilover. And makes a strange noise if I hit a bump at full lock.
  6. May 31, 2017 at 7:09 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    I think mine was hitting after the lift went on too, sometimes. I removed the sway bar and never looked back.
  7. May 31, 2017 at 7:36 AM
    CO_0321er
    ill try greasing the steering stops. but it bangs before it hits full lock.
  8. May 31, 2017 at 7:43 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Lca bushings or balljoints
  9. May 31, 2017 at 7:49 AM
    medic2230
    Murph
    Bama! Roll Tide
    I was thinking lower ball joints also.
  10. May 31, 2017 at 9:41 AM
    rjlem
    rjlem Well-Known Member
    Rick
    Franksville, Wisconsin
    2011 Reg Cab 4WD 2.7 A/T Bought used
    Int. Wipers, OEM Cruise, Fiamm Horns, Access Cover, Bed Mat, WeatherTech Floor Mats,
    Non-OEM brake pads and clips can rattle like crazy
    Listen for a metallic "click" when applying the brakes reversing after you come to a complete stop going forward.
  11. May 31, 2017 at 11:48 AM
    Pigpen
    Dan
    Northwest Montana
  12. May 31, 2017 at 12:08 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Radiator frame bushings.
  13. May 31, 2017 at 12:10 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    My 07 did that too. I never did figure it out before I got rid of it
  14. May 31, 2017 at 12:10 PM
    eon_blue
    Azusa, CA
    Do you still have your sway bar on? That'd be the first thing I'd check.
    Lower ball joints shouldn't make a loud "metal brick on brick" clanking sound but if they are, I wouldn't drive that truck at all and get it towed to the nearest shop. If they were indeed that bad it should be easy to check, jack up the front wheels and see if they have any side to side play in them. If they were that bad there would likely be a bunch of play in them.
  15. May 31, 2017 at 12:26 PM
    CO_0321er
    figured it out. had the truck at an offroad shop to fix a clunking issue i had. they fixed it. and while they were im assuming they loosend the lower control arm cam bolts. I torqued them back to 100 and each one had at least 3/4 rotation before torquing. some more. i didnt think to re tighten these as i did a few weeks ago. needless to say, wont be going back to that shop again.
  16. May 31, 2017 at 12:34 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Damn! That sucks
  17. Jun 2, 2017 at 6:38 PM
    ParkCity_Marty
    ParkCity_Marty Member
    2008 TRD Sport MT
    Dangit. I saw the thread title and hoped to find nudes. ;)
  18. Jun 2, 2017 at 6:49 PM
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    I am getting a similar noise. Mine only makes the noise when it is cold and i first move. I have noticed that sometimes the noise happens if with the steering wheel straight i shift into reverse and roll backwards and very slightly tap the brake pedal. It almost sounds like the coilover is loose or something to me, but i think it is my brake pads. Im using autozone pads and their crappy retainer springs.
  19. Jun 2, 2017 at 8:48 PM
    CO_0321er
    mine was similar. happened everytime i started cold and backed up. like me, make sure your lower arms are torqued.
    does it happen everytime you shift from R to D and D to R and press the brake?
