Done
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CO_0321er, Jul 23, 2017.
  1. Jul 23, 2017 at 7:42 AM
    CO_0321er
    CO_0321er [OP] Well-Known Member
    Done
  2. Jul 24, 2017 at 5:18 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I measured last week.. 27.5" from the bottom face of the top shock mount to the center of the lower shock mount.
    I have the heavy pack with thr AAL installed
  3. Jul 24, 2017 at 6:24 AM
    CO_0321er
    27.5"?? hot dang. looks like I'm gonna get the extended 5100s. gotta look and see if fox sells anything that long
  4. Jul 24, 2017 at 6:46 AM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
  5. Jul 24, 2017 at 7:10 AM
    CO_0321er
    im not a fan of the icon stuff. I may get the fox 2.5 rears. they extend to 25". shock will be my limiting factor, but i won't be topping out when going over bumps like regular length will. I have the 27" RCD 5100s now, and the droop is massive, but the up travel sucks. i bottom out all the time. and its impossible to high lift the side of my truck and get the back wheel off the ground. lol. the 25" fox 2.5 will be somewhere in between. more up travel but less down.
  6. Jul 24, 2017 at 7:51 AM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    The new Dakar heavy duty pack, is the redesigned Standard pack that was available at the beginning of the year. Standard pack that was available at the beginning of the year One of the vendors wrote that the differences were redesign spring clamp, Teflon shims at the end of each leaf, Teflon shams in between each leaf . The new light duty pack is 15 mm lower, they did this by taking out the thirdly from the top but are still charging the same price
    Dogg23 likes this.
  7. Jul 26, 2017 at 7:12 AM
    CO_0321er
    do you know your measurement from eye to eye when the truck is sitting normally? and what kind of weight do you have in the truck?
    you said you have the heavy duty pack with the extra AAL? you must be carrying a lot of weight
  8. Jul 26, 2017 at 7:30 AM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    I can check that tonight to confirm but I think it's 23" at static ride height with no load.
    At the moment I only have a hi-lift and an axe and shovel in the bed. So it does ride a little bit rough.... I have better shocks on order to try and smooth out the ride a little bit.
    I'm also probably going to pull out the AAL since I don't really have that much weight even with all my camping gear.
  9. Aug 5, 2017 at 11:13 PM
    Weirich
    Weirich Drunk_taco
    Travis
    2016 Tacoma access cab TRD Offroad
    OvTuned 4.88 R&P Hypertech speedometer calibrator Rough country 6" lift Toyo open country 285/75R17(old) Cooper STT Pro 315/70r17 Archive garage shackle flip Tough country uni ball uppers Icon 2.5 6" front coil overs Icon 2.5 CDC 6" rear shocks OME cs047r rear leaf packs AllPro HD Sliders Tom woods double cardin single piece drive shaft Magnaflow exhaust Black rock D window rims(old) ICON 17x8.5 Rebound CBI T3 full guard front bumper Smittybilt x20 10k winch HEISS 20" single row light bar ARB on board air compressor
    I'm going to have to double check but if I'm remembering right I measured 31". I also have a block installed though. I have the shocks from the rough country lift and they have a ridiculous amount of extension. Just a heads up, combined with the leafs they make the rear end kind of stiff.
