Done
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CO_0321er, Jul 29, 2017.
  1. Jul 29, 2017 at 9:09 PM
    CO_0321er
    CO_0321er [OP] Well-Known Member
    Done
    tcjacado likes this.
  2. Jul 29, 2017 at 9:11 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Frequently you need to drive a short bit before the locker actually engages. The elockers kinda suck in that way, so if you ever need it for an obstacle, turn it on a bit before you need it.
    Ch78, shakerhood, tcjacado and 2 others like this.
  3. Jul 29, 2017 at 9:14 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    The splines have to line up properly for the diff to lock. No lock? Move forward or back a bit while turning your wheel back and forth. Always works for me
    Frankenstuff and tcjacado like this.
  4. Jul 29, 2017 at 9:17 PM
    CO_0321er
    so its fine to drive slowly in 4lo while the locker is flashing at me? i don't need to be still? but it does actually lock and the light will stay on. it doesn't wait for my wheels to slip
  5. Jul 29, 2017 at 9:20 PM
    tetten
    Andy
    Socal
    It's OK to move while it's flashing, you in fact NEED to move in order to line up the splines
  6. Jul 29, 2017 at 9:22 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    Like the other guys I drive vary slowly to get it to engage. Usually while trying to turn to get the splines to line up. Once it is engaged then yes the light will stay on. May also need to do the same to disengage it.
  7. Jul 29, 2017 at 9:23 PM
    MOC221_
    Frank
    Yeah it's fine, and actually if you stay still it might never lock - again, if the splines ain't lined up it isn't going to happen. In fact, I wouldn't want my wheels to be slipping too much when the locker is trying to engage - could cause damage. That slip thing they told you sounds like traction control tbh
  8. Jul 29, 2017 at 9:23 PM
    tcjacado
    tcjacado Well-Known Member
    You will be fine, as others have suggested. Move forward or backward to engage. Splines need to line up. Enjoy your truck.
  9. Jul 29, 2017 at 9:24 PM
    tetten
    Andy
    Socal
    Wheels slipping has to do with crawl control
  10. Jul 29, 2017 at 9:25 PM
    CO_0321er
    and can i have the locker on while in crawl control?
  11. Jul 29, 2017 at 9:26 PM
    MOC221_
    Frank
    All yours guys, no Crawl here.
  12. Jul 29, 2017 at 10:40 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    No.
  13. Jul 30, 2017 at 8:32 AM
    su.b.rat
    su.b.rat broken truck
    kinda weird OP but this is basically how it works for everyone reporting here using the locker. just use that info to choose wise places to engage and disengage it, where you have a little room to safely move back & forth. cus being in the wrong place for this can be an issue.
