Dongar for Dashcam Question
Discussion in 'Technical Chat' started by bismarck, Mar 16, 2023.
  1. Mar 16, 2023 at 2:47 PM
    bismarck
    bismarck [OP] Well-Known Member
    2023 TRD Off Road
    So I tried sending Dongar this question, and no response from them.
    I wanted to go with the Garmin Mini2. Easy peasy, the dongar plugs into mirror, and cam into dongar.
    I saw that Garmin had the ability to add multiple cams.
    So I was thinking about adding another Mini2 to the rear.
    Powering it however will be questionable.
    I asked Dongar if they made a harness for the rear of the truck ... no response.
    I asked another question, can you mount 2 of their units in series and have everything still work ok? That way I just run a cable to the back of the cab and have power to the back unit also.
    Or is there anything I'm missing?
  2. Mar 16, 2023 at 2:58 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I don't think Dongar makes anything specifically for the rear. If you have a rear USB you could use a second Dongar adapter and route your camera harness to it. Or maybe you could adapt one of these to work with 12vdc switched power that's only on when the ignition is on.
    bismarck[QUOTED][OP] likes this.
  3. Mar 16, 2023 at 3:06 PM
    bismarck
    2023 TRD Off Road
    you know if there's a 12v source that's hot with ignition on? I think that the bed lighting would be only active when the switch is on. I might rip the back apart and see if there's a hot wire I can use.
    Thanks for the link, didn't even look at other stuff. Appreciate it.
  4. Mar 16, 2023 at 3:35 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I don't know what would be best/easiest to tie into in the area of the rear window. Maybe there's wiring there that would be for the JBL amplifier? But I don't know if that would have a circuit that's hot only with ignition on.
  5. Mar 17, 2023 at 6:14 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I would just add a fuse tap to an ignition on circuit in the under dash fuse box and run a wire back to where you want to mount the camera. Since there's no devices back there to tap off of, I doubt Dongar would make anything to do what you want.
  6. Mar 17, 2023 at 6:48 PM
    bismarck
    2023 TRD Off Road
    I'd have to find a way to convert a hot wire to Micro USB. which is what the dongar is made for.
  7. Mar 17, 2023 at 7:30 PM
    HisDad
    Texas at last
    Amazon has Micro USB cables with pigtail wires. Solder and heat shrink tubing.
  8. Mar 17, 2023 at 7:33 PM
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    You can also try the fit cam 4k with the rear cam. That's what I was using before I sold the truck, it was a solid camera.
