Dont buy Aftermarket HL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billas333, Nov 19, 2010.
  1. Nov 19, 2010 at 1:09 PM
    billas333
    billas333 [OP] They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    I changed out my factory Chrome headlights with some eagle eyes Black headlights about 2 years ago. Well for about 9 months now I had moisture build up in my passenger side headlight and I dried it out once with a dessicant packet but everytime I got my truck washed or it rained it just came back.
    Now both my headlights have moisture in them and its an insane amount right now. Super annoyed dont really know what to do,
  2. Nov 19, 2010 at 1:13 PM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    should have sealed them before u installed them. :/ if u got them on ebay a lot of them will leak or get moisture in the headlights.
  3. Nov 19, 2010 at 1:15 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    I have the same ones. had the same problem. I took them out. baked them at the lowest setting to dry them out. The resealed them around the edges with RTV and havn't had a problem since.
  4. Nov 19, 2010 at 1:15 PM
    billas333
    Joel
    NorCal
    Yup thats where I got them, dont know how I am or was supposed to seal them
  5. Nov 19, 2010 at 1:18 PM
    billas333
    Joel
    NorCal
    Oh nice seth! Thanks for the tip man! Did you take the lamp apart or just add sealant around the edges???
    FYI that problem I was having with my headlights shorting out my amps was fixed by moving the HID power cable inside of the amps power cable
  6. Nov 19, 2010 at 1:51 PM
    PreRunnerSeth
    Apex, NC
    Glad you got that fixed. I pulled the headlights out. then removed the bulbs. Set them in the oven on top of a cookie sheet and a micro fiber towel with the lens facing down so that steam could escape out the bulb hole. then set the oven on low and let them bake for a couple hours. I left the oven door cracked. If you roll them around first then tip them over you can just pour out a lot of the water. Then when you seal them. Goop the RTV on pretty heavy. Grab some motor oil can be new or used. dip your finger in the oil and then smooth out the silicone. the oil will keep the silicone from sticking to your finger and will give you a nice clean smooth silicone bead. you will have to rewet your finger with oil regularly.
  7. Nov 19, 2010 at 1:59 PM
    billas333
    Joel
    NorCal
    Life Saver! Thanks man!
