Don't Buy Recon
Discussion in 'Lighting' started by Onion27, Jan 1, 2012.
  1. Jan 1, 2012 at 7:30 PM
    Onion27
    Onion27 [OP] Well-Known Member
    San Antonio, TX
    05 Tacoma Dbl Cab PreRunner
    So I got a set of Recon Diamond White Headlight and Fog Lights for Christmas. Installed them right away. Making sure to not touch the bulb with my fingers. The low beams went out the first time I used them, and the high beams a day later.:confused: I called Recon and they sent a new set right away. Installed the new ones, but this time using gloves to truly make sure I didn't touch the bulb. I got one night of use out of them before one low beam went out the next night.:mad::mad: The only problem I had with the fog lights was the rubber seal was too big; so I switched it out with the ones from the old bulbs. They are still running fine. Although I will never buy another thing from Recon. It's back to Sylvania for me.
