Don't drive truck much?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 58LesPaul, Sep 9, 2016.
  1. Sep 9, 2016 at 3:23 PM
    58LesPaul
    58LesPaul [OP] Well-Known Member
    Jeff
    Kentucky
    2013 Tacoma TRD Sport 4x4 DCSB
    2" Lift
    I have had my 2013 DCSB for about 6 months and have only put about 1200 miles on it. Is there anything I need to do because I don't drive it much? Should I still change the oil every 6 months or 1 year? Anything else?
    Thanks
  2. Sep 9, 2016 at 3:27 PM
    eon_blue
    Azusa, CA
    I'd do the oil every 6 months if you aren't putting enough mileage on it, but as far as anything else goes I'd say as long as you taker her for a spin once a week or so you should be fine.
  3. Sep 9, 2016 at 3:30 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You don't say if its a 4WD; if so make it a point to engage the 4WD when you drive the vehicle. I would worry about moisture accumulation, you should think about getting things hot enough to drive the water accumulation out. If you use synthetic oil you can go 1 year without much worry about the oil itself.
  4. Sep 9, 2016 at 3:30 PM
    Oey12
    Oey12 Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    For the first 4 years I owned my 2012, I only put on about 4K a year. The oil would get changed anywhere between 12 to 15 months and I used Mobil 1 EP as a added insurance. Truthfully any quality synthetic oil (Mobil 1, Pennzoil, ETC) will be fine for a year and a half. I also changed all the diff oils and 4wd to synthetic just to make sure I was running the best fluids.
  5. Sep 9, 2016 at 6:58 PM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    I've had my 2015 for 18 months and am only at 6900 miles. I've only had two oil changes and I pop her in 4WD a couple times during the summer. In winter, 4WD is constantly used. I would still get the oil changed every 6 months, but if you go over here and there, I wouldn't worry. As you can see I average every nine months.
  6. Sep 9, 2016 at 8:28 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I add about 5k miles on my Tacoma a year. I still change my oil every 6 months with synthetic. Same with in cabin, engine air filters. More piece of mind than anything.
  7. Sep 9, 2016 at 8:35 PM
    vtdog
    vtdog Well-Known Member
    NH
    I only put on about 4k/year. I change the oil using synthetic (whatever is cheapest at Wallyworld at the time) with a good filter once per year. The whole point of synthetic oil is that it is more "slippery" and less subject to degradation over time vs Dino oil.
  8. Sep 9, 2016 at 11:21 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    I have a 2012 PreRunner with 5400 miles. I change oil/filter every 6 months with Mobil 1, take it down the road with e locker engaged every 2 months or so. Every week I take it out on the freeway, get it hot, and floor it a couple of times ( read about that here on TW awhile back ). I am not very mechanical, never quite figured out how important/necessary oil changes are in my case but cheap insurance and also I have 8 year VSC so I follow maintenance guidelines. Now that I think about it most of my mileage is blowing the truck out!
  9. Sep 10, 2016 at 8:21 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    2007 with 25,000 miles... change the Mobile One Synthetic every 6 months. Average miles at oil change intervals... 1,388 miles :anonymous:
  10. Sep 10, 2016 at 8:50 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Woahhh! :violent:
