don't hate me, spacer lift
Discussion in 'Suspension' started by TRD 09, Sep 3, 2012.
  1. Sep 3, 2012 at 8:55 PM
    TRD 09
    TRD 09 [OP] Well-Known Member
    Alberta
    09 TRD sport
    okay so I ordered a ebay spacer lift, 3" front, 2" rear with rear shock extensions and diff drop blocks, i plan to run 255/75r17 on stock wheels. I dont offroad much, mostly just getting around job sites and a little trial riding when hunting, I plan on upgrading to a coil over lift and UCA's down the road but for now the spacers are going in. what I want to know is what to look out for with the spacers, what are the common problems?
  2. Sep 3, 2012 at 8:57 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    I would probably say don't jump it haha. Other than that if you aren't a hard core off roader you'll be fine
  3. Sep 3, 2012 at 8:57 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    Broken shocks, leafs
  4. Sep 3, 2012 at 9:01 PM
    medic2230
    Murph
    Bama! Roll Tide
    There are hundreds of taco's running around with spacer lifts on them. Your not gonna die from it. As long as you know what you have a drive it appropriately then who cares. Your truck will be looking good. And here comes the :crapstorm:
  5. Sep 3, 2012 at 9:09 PM
    TRD 09
    Alberta
    09 TRD sport
    im fine with a harsh ride, i just sold a f150 with 37" millitary tires that rode like it didnt have suspension but im not a fan of broken shocks, what causes bent/broken shocks?
    as for spending money on something im going to ditch... 2 new vehicles and a new house in the last 4 months after moving accross country means I can afford a spacer lift without the wife complaining, believe me, I normally curse people for not doing it right but this is my option at the moment
  6. Sep 3, 2012 at 9:10 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    spacers severely decrease the ride quality offroad. prepare to feel like you have no suspension at all, I had a spacer lift in the front for a week and removed it because i felt like I downgraded my truck. It was terrible.
  7. Sep 3, 2012 at 9:11 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    if you arent putting larger tires on then just keep it stock til you are ready for a suspension lift
  8. Sep 3, 2012 at 9:13 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just take it easy and you'll be fine. :thumbsup:
  9. Sep 3, 2012 at 9:23 PM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    The 3" front spacers may require you to go get new UCAs sooner rather than later, unless you dont care how fast your tires ware. You may be fine, but you never know. At the moment there is one GB on LR UCAs (see my signature), and there is another one for Camburg Uni-Balls or Camburg Ball Joint UCAs that is about to start, might want to keep your eye on those, since that is your long term plan.
  10. Sep 3, 2012 at 9:35 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Those diff drop will do more harm then good for ya.
  11. Sep 3, 2012 at 9:35 PM
    TRD 09
    Alberta
    09 TRD sport
    Okay so after my moment of weakness in ordering the kit I emailed the seller and asked to cancel the order, I'll save and get the set up I really want, I spent a lot of money on the truck, the suspension is no place to be cheap
  12. Sep 3, 2012 at 9:36 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Smart decision, you will be happier when you get what you want then settling
  13. Sep 3, 2012 at 9:46 PM
    Goflight2
    Goflight2 Well-Known Member
    Southern Cal
    Supercharged 2011 4x4 LB
    TRD Supercharger Snug top SL Window Tint 5% rear, 35% front, 40% windshield Avid Off Road bolt on sliders Andres Toyota Horns Hard-wired Garmin Nav Weather Techs 5100's in front Rear TSB Bed Extender OEM Roofrack TRD Exhaust Ultra gauge 18" Monster XD's on Nitto Terra Grapplers
    Icon Stage 4.
  14. Sep 3, 2012 at 11:39 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    Long Travel. :D ( which I don't have )
  15. Sep 4, 2012 at 12:11 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I was going to say I don't hate you because
    Glad to see you made the right decision.
    It's better to wait to get what you want than waste money & hate what you got. +1
  16. Sep 4, 2012 at 9:14 AM
    TRD 09
    Alberta
    09 TRD sport
    Okay if I go with a 3" coilover lift with UCA's and AAL rear like camburg, what is the max tire size I can comfortably run on stock 17" TRD wheels?
  17. Sep 4, 2012 at 9:16 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    An AAL isn't a spacer though.
  18. Sep 4, 2012 at 9:22 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    285/70/17. Tires could be close to rubbing the UCA though.
  19. Sep 4, 2012 at 10:08 AM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    depends on how "comfortable" you are with cutting some plastic or cab mount away.
    265s are the biggest toyota says you can go.
    275s some people run with no probs.
    285s you will prob need to atleast trim a tad of plastic. Maybe more depending on profile of tire and how much you flex it. At 285s you get into the cutting.
  20. Sep 4, 2012 at 10:10 AM
    TRD 09
    Alberta
    09 TRD sport
    What about a 255/80r17, that's a little over 33" but 10" wide,
