Dont know what power amp to get
Discussion in 'Audio & Video' started by TheMrGExperience, Jul 7, 2011.
  1. Jul 7, 2011 at 1:31 PM
    TheMrGExperience
    TheMrGExperience [OP] Because Tacos are too mainstream...and Im poor.
    Garrett
    Slidell, LA
    01 GMC Sierra z85 4x4 4.8L RCLB
    Debadged, 4x6 to 6x9 rear speaker conversion
    I just ordered a polk audio sr124 sub but dont know what amp to get. peak power is 1400watts and the rms is 700watts. impedance is 4ohms
    Does that mean i need at least a 1400 watt amp or can i get away with running a high quality JL or PA 500watt amp? I have very little knowledge about wattage and i dont even know how the eff ohms fit in to this equation so could some one enlighten me please? Thanks!
  2. Jul 7, 2011 at 2:34 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Wow, almost 7-1/2" deep with a vented pole piece (8-1/2" deep box?) - where you putting that?
    Even if you don't need the following info, it might be handy for others...
    700 Watts RMS is the power rating that will cause the motor to safely avoid thermal damage from long term use at that level.
    1400 Watts peak is the power rating that will cause the motor to safely avoid mechanical breakdown from over extending itself.
    A high quality 500 Watt amp will easily under the RMS rating, and it's highly unlikely (IMO) to exceed the peak of 1400. Going from 500 to 700 RMS Watts will not be all that much difference in volume - would probably have to have two running side-by-side for an A-B comparison to really detect the difference.
    If it were me, and the price was about the same, and I could afford it, I would go for the JL Audio HD 750/1. Driving the PA SR124 - with two 4-Ohm voice coils):
    JL 750/1=750 Watts at 2 Ohms with THD <0.03% at 12 up to 14.4 volts
    PA 1200.1=800 Watts at 2 Ohms with THD <1.0% at 14.4 volts power (not spec'ed, but probably around 600 at 12Volts).
    So at the 13.5Volts I typically see on my Scanguage, the JL Audio amp will deliver the same or more RMS power at a lower distortion level. And since the JL uses a more highly regulated power supply, it will be capable of driving the sub louder when the engine is at idle. Hence my vote for the JL.
  3. Jul 7, 2011 at 3:47 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    What type of box is it going in?
  4. Jul 7, 2011 at 5:34 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Sub'd out of curiosity... :popcorn:
  5. Jul 8, 2011 at 10:34 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    +1 :violent:
  6. Jul 8, 2011 at 12:10 PM
    pinktaco808
    pinktaco808 Hot Steppa
    in the bed ehhh
  7. Jul 8, 2011 at 8:41 PM
    TheMrGExperience
    Garrett
    Slidell, LA
    Back seat of the access cab:) thanks for the info!
    slant ported
  8. Jul 8, 2011 at 8:51 PM
    TheMrGExperience
    Garrett
    Slidell, LA
    would the JL 750 have enough power for a sealed box if i went that way?
