Don't Read this unless you want a home made Cheap Roof Rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Early Man, Jun 28, 2019.
  1. Jun 28, 2019 at 1:22 PM
    Early Man
    Early Man [OP] Well-Known Member
    Sand 2016 Sr 5
    With all the talk on what roof rack to buy, I decided to get some pics of my home made one that set me back about 60 bucks counting paint and than another 12 for V blocks made of untreated Fir 4x4 wood, carpet and scavenged plywood from other projects, and oh yeah a smidgen of copper water pipe with carriage bolts .
    If you don't like it scroll on by .
    1. Da Camo Kayak rack because I don't know anything about modern cameras and the blasted thing is invisible .
    2. A Detail of the V blocks, that are held in place by carpet on the insides and 1 carriage bolt, so they can be removed easy .
    3 The back side of the V block .
    4. Over all pic of the V blocks at the front .
    5. A better shot of the rack .
    6. The rear view .
    7. Another rear view with maybe some details . There are steel L Braces in the middle, but painted black, which stiffens the rack . This rack is already 6 years old and fit a 2012 Tacoma.
    8. Detail of the rear blocks .
    9. Closer up detail of the rear block and carpet inside .
    10. Carpet on a rear V block top .
    11. Inside the V block botton where you can see one of the copper fitting I made for the bolt to pass thru .
    12. V Block simply removed .
    13. Why I need a rack. The Kayaks are 14 feet 6 inches and the canoe is 16 feet 1 inch .
    Optional :
    14. My wife resting her arm to hold the kayak more or less leveled as it is not supported totally by the V block yet.
    15. With very little pressure I can pull down a little bit to get the Kayak aimed into the forward V block. A guess is I pull maybe 15 pounds down.
    16. I just like this shot.
    17. Last shot Loaded and ready to go . :)
    I will be happy to answer anything, but this is just basic woodworking. There are Eye Bolts anywhere a bolt will be on the rack. It is screwed and glued at all connections. I used a Forstner bit on the lower Eye bolts so the nuts could be recessed and the bolts trimmed so nothing get scratches and no one gets cut .
    The 2 blue straps are all that hold this down, and the forward ends are trapped in the OEM bed tie downs .
  2. Jun 28, 2019 at 1:33 PM
    bigonenine
    bigonenine Carnitas Taco
    NJ
    2018 DCSB TRD OR
    Nice! Looks like it would be easy to remove too
    Early Man[OP] likes this.
  3. Jun 28, 2019 at 1:39 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
  4. Jun 28, 2019 at 1:40 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Nice writeup!
  5. Jun 28, 2019 at 1:48 PM
    Early Man
    Sand 2016 Sr 5
    Removing it totally is cake. Remove the 2 blue straps, turn the D rings away to the tailgate. Grab the center lift a little and slid it back. I just sort of ease it down then raise the front over the wheel wells slowly moving it back. A point comes where the rear base hits Earth and from there I just let go and it stands up. My wife will be around to make sure it doesn't tip all the way over. The top rails are 10 feet long .
    I can't say how much it will carry. The most I have had up there is 2 kayaks at 60 lbs each, the canoe weighs less than a single kayak about (50 kevlar gel coat), and I maybe had 6 sheets of 1/2 inch plywood up there. If I need to move more weight there is the 1 ton Dodge Dump / plow rig for that .
    On Edit: When this was in the 2012 My wife and I lifted this out over the side. The 2012 was a lot lower at bed sides height.
    tonered likes this.
  6. Jun 28, 2019 at 1:49 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    this is awesome
    Malvolio and Early Man[OP] like this.
  7. Jun 28, 2019 at 1:53 PM
    Early Man
    Sand 2016 Sr 5
    Oh, these kayaks have Rocker, which is the keel isn't level but goes up in the bow and in the stern. The V blocks are not the same ft or rr. The front also have wood 3/4 inch spacers under the 4x4. I did not want the center of the kayaks to touch the center cross bar.
    This was really hard for me to get the modern camera to see a gap at the keel to the center cross bar . I am OLD I am used to old 35mm film cameras I can't see the blasted screen on these.
    tonered likes this.
  8. Jun 28, 2019 at 1:56 PM
    Early Man
    Sand 2016 Sr 5
    I hate it that these racks cost so much.. And then sometimes they can't do what you wanted anyway. and or of they can you gotta drop more heavy dough to get the accessories.
    tonered and Bleep100 like this.
  9. Jun 28, 2019 at 2:34 PM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    You da Man!
  10. Jun 28, 2019 at 2:39 PM
    SunRunner
    SunRunner Rub some dirt on it!
    Scott
    PA
    2019 Off Road Looooooooong Bed
    Great job :thumbsup:
  11. Jun 28, 2019 at 3:59 PM
    King Kermit V
    King Kermit V Well-Known Member
    Kermit
    Miami, FL
    2018 Black Tacoma SR5 DCSB
    Taco sauce
    I truly look up to all of you who have this amount of creativity and know how! Nice OP!
  12. Jul 3, 2019 at 12:50 AM
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    Impressive!
  13. Jul 3, 2019 at 3:50 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    OP, that looks awesome, thank you for sharing and the write up :thumbsup:.
  14. Jul 3, 2019 at 4:17 AM
    Early Man
    Sand 2016 Sr 5
    Puttering and packing , about out the door to Maine for the 4th. The blocks that hold on kayaks are off. No boats this 4th. Blocks are not very aerodynamic ;)
  15. Jul 3, 2019 at 4:51 AM
    dnlskier
    17' TRD SPORT MT
    Sweet, where you coming from OP? I am in NH and Maine is awesome place, especially the beaches! Safe travels!
    Early Man[QUOTED][OP] likes this.
  16. Jul 3, 2019 at 5:08 AM
    Mx400ex72
    Mx400ex72 Well-Known Member
    Lehigh Valley, PA
    2019 BR SR5 DCLB
    Ladder racks are like $100 on Amazon/ebay.
    The overland type racks are very expensive, but if you just need to haul some lumber/ladders/kayaks down the road, nothing wrong with the metal ladder racks.
  17. Jul 3, 2019 at 5:33 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Is it safe using your hood as a tie down?
  18. Jul 3, 2019 at 7:15 AM
    ZKH
    ZKH Well-Known Member
    northern Kentucky
    2018 TRD-OR DCLB A/T 4x4 BBP Prem+Tech
  19. Jul 3, 2019 at 7:45 AM
    Tommyb08
    Tommyb08 Well-Known Member
    Tom
    Jersey Shore - Ocean County
    2017 TRD Sport 4X4 DCLB Black
    Good job with that, very creative. :thumbsup:
  20. Jul 3, 2019 at 11:55 AM
    Bleep100
    17 Sport
